03 7.3 Excursion misfire and killing problems
Two weeks ago while pulling my trailer my ex started to misfire. Changed fuel filter. No change. Removed hydra chip. No change. Put some fuel conditioner. Ran truck for two weeks with no problem. I'm out of town with work of course. Wife was driving Ex started running rough and killed. Restarted ran a mile and killed. Drained some fuel from filter and made it home. Still running rough. Drained filter into glass jar with no signs of water. Son checked for codes. None were present. Truck has aftermarket air filter, walker btm, and hydra chip. Any suggesting?
I had a start, then it would start missing problem that mirrored some of your symptoms. I pulled the UVCH harness and while they were slightly loose, I don't think that was the problem. I then pulled the ICP sensor and there was oil in it. When I replaced the sensor all seems good again. The ICP sensor is a lot easier to check first before pulling valve covers. Ask me how I know or just look. Somebody has a picture here or just do a search for ICP picture.
Finally got home to work on the Ex. Checked fuel pressure . Good at 57 psi. Checked fuel in bowl and filter ok. Disconnected hydra and miss was still there. Took to a friends shop and hooked to his lap top. Ran KOEO and KOER test. Found small problem with #8 injector. But nothing to cause killing and miss fire. Dropped tank and big screen was in pieces in bottom of tank. Screens were clogged with screen pieces and rust. Rust coming from vent pipe of filler next. Performed hutch method of pickup and installed external filter. Fuel pressure went up to 60 psi. Running good so far.
It can be frustrating trying to nail this type of problem down as there are a number of different things that can cause the similar symptoms. Maybe we should just take them to the dealer and have them put their super duper diagnostics on them and they will have it fixed lickity split. Of course that would be cheap too.
Mine was the ICP, but it can be so many other things.
I'm just glad for all the folks here that are ready to help us work through stuff and get our trucks running right again.
