2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
View Poll Results: 5.0L V8 or 3.5L EcoBoost to Replace 6.2L Super Duty Engine?
5.0L V8. The Super Duty should have a base V8.
73
68.22%
3.5L EcoBoost V6. It offers better capabilities.
34
31.78%
Voters: 107. You may not vote on this poll
Question of the Week: 5.0L V8 or 3.5L EcoBoost to Replace 6.2L Super Duty Engine?
Old 02-09-2015, 09:11 PM
Powerdude's Avatar
Powerdude
Powerdude is offline
Remember that oftentimes, price points dictate features. Ford tries to cover the most likely price points so that they can sell more trucks. They make their money using economies of scale.
The Ecoboost is a premium F150 choice. If they put it as a base engine in the F250, how are the people who just paid a premium price for the Ecoboost engine going to feel if there is no premium for it in the SuperDuty?
Marketing department would have a heart attack trying to explain that one. You can't screw your customers that way. The SuperDuty line doesn't sell as many trucks as the F150, so it makes no sense to have 3 engine choices.
  #107
Old 02-09-2015, 09:21 PM
Austin J.'s Avatar
Austin J.
Austin J. is offline
The 5.4 was a base superduty engine, but a premium 1/2 ton engine.
  #108
Old 02-09-2015, 09:50 PM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
You could look at it the other way, meaning, if Ford runs the engine in the Super Duty it certainly must be a desirable engine choice for the F150. After all it's street cred will have just been boosted.
  #109
Old 02-10-2015, 04:34 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,221 Likes on 803 Posts
The 6.2L in the superduty was a $3000 option in the F-150 from 2011-2014.
  #110
Old 02-12-2015, 07:24 PM
KP1001's Avatar
KP1001
KP1001 is offline
Originally Posted by dkf
Neither. The adding 2 cylinders to the 5.0l would be fine to me.
Just because you throw a smaller engine in a truck like the SD does not mean mpg will be much different.
I agree. a 351 will get better milaeage than a 460 until its under a load.
Its amazing how many people dont realize it. an ecoboost will get better mileage than a 7.3 until you load it down
  #111
Old 02-15-2015, 06:40 PM
Pshicker's Avatar
Pshicker
Pshicker is offline
My opinion, is that Ford has a ton of $$$'s invested in the development and improvement of the 6.2L. I think you may see a turbocharged version before you see an "ecoboost".
Just my opinion.....
  #112
Old 02-16-2015, 07:27 AM
LSchicago2's Avatar
LSchicago2
LSchicago2 is offline
Originally Posted by DCP
My two cents is, Ford already has a unreliable turbo diesel, the last thing Ford needs is a unreliable turbo gasser. I think my 6.2L works well in my truck, and I probably more heavy trailers than 90% of the diesel owners here on FTE, I just think the 6.2L in the SDs should be tuned the same as the 1/2 tons and say screw the duty cycle argument. Lastly, I never drove a new 5.0L, I have no clue on their power. But, a 5.0L, (302 c.i.d) seems to be a little small for a heavy duty pickup. Personally I'd like to see big blocks come back, and the manual transmissions. Ford could make a modern 460 like motor that makes big power and torque at much lower RPMs unlike the modern V8 and V10 engines. But, I believe big blocks and manual transmissions are long gone forever in Ford trucks.
The 5.0 is much stronger than the 5.4 Offered in the SD for years, and with the next SD trucks being 700-1,000 pounds lighter, it could be a very smart choice. I can get up to 25 MPG in my 2013 F150 5.0, so they are very efficient too.
  #113
Old 02-16-2015, 08:39 AM
parkland's Avatar
parkland
parkland is offline
Has anyone compared towing with an ecoboost in a lower gear to keep RPM's up and boost down?
I wonder if the MPG would be better?
  #114
Old 02-17-2015, 07:17 AM
LSchicago2's Avatar
LSchicago2
Often times the 5.0 will get better MPG than the Eco, because the Eco will always be under boost while towing.
  #115
Old 02-17-2015, 08:30 AM
parkland's Avatar
parkland
parkland is offline
True, but with the ecoboost, lower RPM's = more boost, so what I was getting at, is that maybe higher RPMs and less boost would net better fuel economy.
  #116
Old 02-17-2015, 09:28 AM
KP1001's Avatar
KP1001
KP1001 is offline
Question
How can you have less boost with higher RPM? Is the turbo designed to decrease with higher RPM?
Even if the turbo does back off, the smaller motor will still be spinning faster which would use more fuel. Would it not?
  #117
Old 02-17-2015, 09:36 AM
KP1001's Avatar
KP1001
KP1001 is offline
And for what its worth, I think the 302 would still be too small for SD's. Do us all a favor and bring back the 7.3,
decent mileage when empty and will run longer than anything else if loaded constantly.
  #118
Old 02-17-2015, 12:08 PM
parkland's Avatar
parkland
parkland is offline
Boost is generated higher the higher the engine is loaded.
That being said I'm not an expert on the ecoboost and I don't know what the computer would do.
  #119
Old 02-17-2015, 12:13 PM
parkland's Avatar
parkland
parkland is offline
Fist of all, the 7.3 is never coming back, there is no point sitting around and whining about it.
And the size of an engine does not automatically mean it will last longer compared to a smaller motor.
It is perfectly possible using different metal alloys, technology, etc, to make a smaller faster turning motor last even longer than a larger slow turning one.
In general practice, usually larger engines have lasted longer and had lower end TQ, but this is comparing apples to apples, and the ecoboost is not an apple.
  #120
Old 02-17-2015, 12:25 PM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
I've tried locking out 6th gear,several times, when towing the boat to see if the mileage would be any better. The mileage was actually worse. My boat weighs about 4,200 lbs. When I had my enclosed car hauler I always locked out 6th just to keep it from shifting too much. Loaded that trailer weighed about 7,000 lbs. No matter what I did with that trailer my gas mileage was poor.
Quick Reply: Question of the Week: 5.0L V8 or 3.5L EcoBoost to Replace 6.2L Super Duty Engine?
