1960 F100 Fuse block/headlight switch
here is problem I am having:
Turn on lights, HI and LO beams on along with HI beam indicator light in gauge, when I tap on dimmer switch the gauge panel/tach/gauge pod under dash lights turn on and off, not the HI beams...tried new dimmer switch, same deal-any ideas?? Just started, was intermittent at first. I could tap on dimmer switch a few times and HI beams would turn off, then turn back on randomly while driving sometimes....now they stay on no matter how many tome I tap it on and off.
Since you already changed the switch, it sounds like a short in the wiring between the headlight switch & the hi-beam switch. There should only be one hot wire from the light switch that goes to the hi-beam switch. From there, it selects either the hi or low.
As for the dash lights, that is almost normal on any car over 30 years old.... Maybe a coincidence that they started together? Usually a bit of WD-40 in the dimmer rheostat fixes this.
I put my headlights on relays years ago to take the load off of the switch, as well as brighten up the lights. That & halagen lamps gives me lighting as good as modern cars.
Does The dash light dimming/cab interior light resister portion of the light switch function. It sounds like you may need to pull the switch out and test each circuit. The only thing the beam dimmer switch should have control of with the dash is the high beam indicator light.
Just throwing-out some thoughts
These are the frustrating but kinda fun in a odd way problems we get with old trucks
Notice that the connectors with the asterisk * came with the junction (fuse) block assy, but the connectors with the triangle did not, were sold by themselves or came with the dash wiring harness.
There are three different types of these connectors, parts catalog only says AR (As Required), doesn't say which is which.
C2AZ-11A647-A .. Junction Block Assy. / Obsolete
Applications: 1960/62 F100/600 / 1961/67 Econoline / 1963 F100/750 // 1960/63 Galaxie / 1960/64 Falcon/Comet / 1962/64 Fairlane.
NOS PARTS LTD in Waxahachie TX has 7 = 972-927-2201.
WESLEY OBSOLETE PARTS in Liberty KY has 7 = 606-787-5293.
Joe; that sounds pretty wild, for me when electrical things start acting weird, its usually a grounding issue. Might check the ground strap for the gauge cluster?
mountain dewd
02-11-2018 07:44 PM
weblawdog
05-15-2015 12:11 AM
BULLETPROOF4.9
09-06-2010 08:43 PM
jimbo beam
10-27-2005 09:19 PM
