Lost ignition keys.. how do i remove lock cylinder?
Yeah yeah, I know, i should know, but my memory isnt so hot! Lol!
Picked up my ol Powerstroke last week, which is a story all on its own.. Couldnt ever find my damned ignition keys! Not paying $350 for a locksmith to come out and make a new key!
So how is it we remove the lock cylinder without jackering things up?
Yes, you will have to drill through the tumblers, and then use a screwdriver to turn the ignition to "Run", and then push in the lock pin (underneath) to pull the assembly out.
You can also drill out the lock pin, but there is a plate at the back of the ignition switch which only allows it to be pulled out in the Run position, so you still have to drill through the tumblers. Use a drill bit about the same diameter as the width of the key slot.
Received 3,107 Likes
on
on
on
i got my 91 home finally, had it towed, went to work on it but cannot find the keys. on my95 there is a hole to put a pin in, cannot find one on the 91. i bought a new locking cylinder for the ign. and as soon as i tear everything up the keys will probably show up. do i have to drill the tumblers out?
