DEF milage per tank
My suggestion...is to get the ford spout. Then use it to fill the tank. It seals around the opening and will quit allowing more def into the tank when full. This is important for the winter time when the tank might freeze. Over filling the tank could cause a problem.
With heavy towing I get around a tank full every 5k as well.
I would run it down till you get the 200 miles till empty message and then fill till full.
Stroker 94 1/2
31
03-14-2009 10:54 AM
