Having a tough time selecting wheels. Going to do a leveling kit and trying to decide on sticking with 20' rims or go to an 18'. Attach photo's if you have something similar to this. Need some help. Thanks.
i had a tough time deciding on wheels as well, so i stuck with the oem 18's or now. I do not have a leveling kit though... here's mine with a 3.5 lift. Hope it helps.
I'm not a big fan of 20" wheels though... so sticking with my oem 18's was still ok with me.
-12 means 12mm offset wheel to make the stance (footprint) wider by total of 24 mm, right?
Thanks.
No lift and no rubbing after slight trimming of the rear plastic on the front fender wells. Unless you had a factory truck right next to mine you'd never know I trimmed. As far as how much more it sticks out....have to find someone a little more tech/math proficient.
Not a great pic since the ground wasn't level but gives you an idea of the stance from the front.
