flathead v8 camshaft problems
Old 10-23-2014, 08:04 AM
Clark wisely's Avatar
Clark wisely
Clark wisely is offline
i am currently rebuilding a Flathead at college. the way it started is i got a 52 model 239 Flathead gave to me and when i tour it all down i found out that the block was junk it had repairable cracks in the cylinder walls to the valves. so i found another block on craigslist to use it is also a 48 stud block. and i put my old cam in and ground my own valves and also got the crank and the pistons all in and when i went to see how the fuel pump push rod felt that's when i realized i have a MAJOR PROBLEM. my camshaft from my old engine is to short and i dont no what to do i thought all the 8ba camshafts were the same. also it looks like the oil pump idler gear will only half of the cam block.
Old 03-04-2015, 06:10 AM
big job's Avatar
big job
big job is offline
one question what do you mean by "48 stud block") I mean just what
exactly are you working with. a 1948 car block or a 24 stud oba 8ba etc
Old 03-07-2015, 07:12 PM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is online now
I think he's counting all the studs, 24 per side equals 48.
djcapron
05-06-2010 09:59 AM
idaho211
10-04-2009 10:40 AM
bergieb
01-13-2009 03:28 PM
David-ID1
1947 and Older Ford Trucks
03-11-2006 12:51 AM
danbo
10-18-2003 09:10 PM
Quick Reply: flathead v8 camshaft problems
