1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
ABS light on after gear swap
Old 10-23-2014, 12:02 AM
Trucker Kev's Avatar
Trucker Kev
Trucker Kev is offline
I just went from 3.73 to 4.30 gears on my 2007 f250 6.0. It has the standard Sterling 10.5 rear and Dana 60 front. My mechanic friend who did the swap said the ABS light came on during his test drive but the truck drove fine. I was of the understanding that the truck would not need to be recalibrated for proper speedometer and transmission function, but what about the ABS? Any thoughts?
Old 10-23-2014, 06:11 AM
Tom's Avatar
Tom
Tom is offline
How was the speedometer? Was it reading correctly? If so you should get the truck scanned to see which codes are showing.
Old 10-23-2014, 06:25 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
Based on what you're telling us, I would guess that the VSS sensor on the rear differential has a minor issue, or was installed incorrectly during the gear swap. Like Tom asked, is your speedometer working OK?
Old 10-23-2014, 07:10 AM
Trucker Kev
Thank for the replies. The truck is still at his shop. He didn't mention anything about the speedometer not working correctly but I'll clarify that with him. I'll check for codes when I pick it up later today. Am I correct that nothing needs to he recalibrated electronically due to the new gears? The gear swap was all we did.
Old 10-23-2014, 07:43 AM
Tom's Avatar
Tom
Tom is offline
No, nothing needs to be recalibrated because of the gear change. The speed sensor operates off of a tone ring in the rear differential. This tone ring spins once for each tire revolution, and it doesn't care how many times the pinion has to spin to make that happen.
Old 10-23-2014, 10:30 PM
Trucker Kev
Still scratching my head on this one. I drove about 100 miles today. The speedometer works fine. The truck drives and shifts fine. I have the PHP/edge tuner/monitor and its not finding any codes.
Old 02-14-2015, 01:10 PM
sdwelling's Avatar
sdwelling
sdwelling is offline
OK, just to be certain - if I change the ring & pinion in my 2012 F450 from 4.30 to 3.73, I don't need to get the speedo/odometer changed because the tone ring on the rear ring gear is responsible for this?? Will I need a new/different tone ring?
My greatest concern is that I am in 6th gear by about 35 mph with the 4.30s. Any speed increase beyond that is all RPM - but boy, does it roll.
Old 02-14-2015, 01:47 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
That is correct , the speedo will stay the same. The only way it would change is if you changed the tire size..
Impcon1966
07-09-2019 08:43 PM
mots42
01-14-2014 08:47 AM
mackda600
48
03-04-2011 02:42 PM
MaryfPoppins
1978 - 1996 Big Bronco
16
06-29-2009 11:43 PM
Katmandu
09-09-2005 06:29 PM
Quick Reply: ABS light on after gear swap
