Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 10-22-2014, 10:07 PM
Fireguyjoe Fireguyjoe is offline
Fireguyjoe is starting off with a positive reputation.
Steering column question power vs manual
Good day to all. I have a 74 ford f100 super cab that is in need of a steering column. It is an automatic with manual steering. I have found one from a 73 ford f100 automatic but it has power steering. Will this work? If not anybody have a good source for one? Thank
Old Yesterday, 07:25 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
What's wrong with your steering column?
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2013 Escape FWD 2.0L Eco-Boost
Old Yesterday, 03:42 PM
It was not shifting properly. I am still not a hundred percent sure what the problem was (have not played around with doing much repair since a teenager so this is a new project for me) but when I pulled the column and looked at the tube inside the tube (thinking this is called a shift tube) that someone had done some welding to what looks like a metal piece that locks into the shifting mechanism somehow and it had broke and the tube also had a hole burned in it while welding. I think I could just replace tube (or someone more knowledgeable then me could) but had found the column mentioned for 50 dollars so wanted to see if I could go that way. Thanks
Old Yesterday, 05:47 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to behold
No, they don't interchange. The power steering column is shorter than the manual steering column.
On your column, replacing the shift tube is simple. You should also check the shift collar (Ford calls it a shift socket). This is a common failure point.
Old Yesterday, 06:00 PM
Shift tube contains a rectangular piece that fits into the shift collar, locks it in place.
This piece was originally "sweated" onto the tube, same method is used to attach front sights to many pistols.
This piece falls off, down inside the mast jacket (steering column shroud), then people have to retrieve it, weld it back on.
C9TZ-7212-E .. A/T Shift Tube - Use with Power Steering / 26 11/16" long / Obsolete
Applications: 1969 F100/250 2WD from serial number D96,001 / 1970/77 F100/250 2WD
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 850 (!) = 800-476-9653.
D5TZ-7228-A (replaced C5TZ-7228-A & C9TZ-7228-A) .. A/T Shift Collar aka Socket / Available from Ford.
This pot metal collar has an internal 'bridge' that connects it to the shift tube. Over time, the bridge begins to crack, eventually breaks off.
Applications: 1965/77 F100/350 / 1973/77 Bronco.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Power Steering Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 3 11-02-2013 08:31 AM
71 F100 STEERING COLUMN FESTUS65 1967 - 1972 F-100 & Larger F-Series Trucks 4 09-29-2011 02:51 AM
1973 F-100 Power Steering Conversion pcta12 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-15-2006 06:31 PM
Chrome tilt steering column 74lowf100 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-12-2006 07:48 PM
steering column swap ? sasgc69 1967 - 1972 F-100 & Larger F-Series Trucks 7 11-11-2002 08:44 PM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
