Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 10-22-2014, 01:45 PM
KsCop's Avatar
KsCop KsCop is offline
Step Out of the Vehicle..
KsCop is gaining momentum as a positive member of FTE.
Anti-Dieseling Solenoid
Has anyone installed an anti-dieseling solenoid onto a Carter YFA carburetor?
I think that would help my run-on issue at shutdown. I have an older carb that has the bracket, and I can get the solenoid.
The bracket mounts using two existing screws in the carburetor. What I'm wondering is if by removing and re-installing those screws if it will mess with the gasket seal and cause any leaks.
The solenoid just takes 12v Key-On power. For those that don't know, the idea is that when the power is off, the solenoid closes the throttle plate on the carburetor, keeping fuel from getting sucked in at shutdown and preventing run-on. As soon as the key is on, the solenoid energizes and pulls the plunger back, allowing the throttle plate to crack open a bit (under spring pressure) as it should.
It seems like a pretty straightforward deal, as long as by installing the bracket I don't mess up the carburetor.
Thoughts anyone?
__________________
1985 F150 4x4 4.9 I6, 4 speed w/granny
1963 F100 4x4 292 Y-Block, 4 speed w/granny
2005 Chevy Uplander
(The OttoMobile - Only vehicle the Great Dane fits in)
2005 Pacifica (Wife's Ride)
Old 10-22-2014, 02:28 PM
1986F150six 1986F150six is offline
1986F150six has a great reputation on FTE.1986F150six has a great reputation on FTE.1986F150six has a great reputation on FTE.1986F150six has a great reputation on FTE.1986F150six has a great reputation on FTE.
I believe the screws used in mounting the bracket are external, only. [going from memory]
Check with Bill Vose [A.K.A. 85lebaront2]... he knows a thing or two about carburetors!
__________________
1986 F150 4.9L 4 speed manual O.D. Duraspark conversion with Carter YF
Old 10-22-2014, 02:55 PM
KsCop's Avatar
There are two bolts that hold the bracket in place. They both go through part of a gasket and into bottom half of the carburetor. In pulling the old bracket off, I don't think it will cause any issues, but thought I'd check if anyone else had done this.
The solenoid that was on the old carburetor is bad, so the search is on for that as well.
__________________
2005 Chevy Uplander
Old 10-23-2014, 02:55 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a good reputation on FTE.Ken Blythen has a good reputation on FTE.Ken Blythen has a good reputation on FTE.
Does this help?
1985 FORD F-150 Idle Stop Solenoid
__________________
1983 F250 XLT 2WD, 351W, T19, 3.54 D60
1942 GMC 6x4
Old 10-23-2014, 07:08 AM
Tried to "rep" you, Ken, but was told that I am in "rep jail".
__________________
Old 10-23-2014, 10:41 AM
KsCop's Avatar
Quote:
Originally Posted by Ken Blythen View Post
LOL
That's the one I ordered about 2 minutes after starting my search.
Should be here in a few days
__________________
2005 Chevy Uplander
Old 10-23-2014, 11:45 AM
JimsRebel's Avatar
JimsRebel JimsRebel is offline
JimsRebel has a good reputation on FTE.JimsRebel has a good reputation on FTE.JimsRebel has a good reputation on FTE.
If you still have a feedback Carb you could just energize the feedback solenoid which will drive it lean. Not sure if this would be enough or not to stop the run on.
Phase one testing...
You would use a relay that powered the feedback solenoid via hot power with KEY OFF, when the relay relay energized with KEY ON power, it would remove power to the feedback solenoid.
Phase two would be adding a Power-Off Time Delay Relay in the hot power feed circuit. This would eliminate the parasitic power drain of the feedback solenoid.
But then maybe I am the only one who still hasn't swap out the feedback Carb yet ...
Jim
__________________
1986 F150 XLT Lariat 4x4 300 C6, 9 inch 3:50, 235-15 tires, sway bars, DS2 w/ GM 4 pin and no computer; 3G ALT swap, PMGR starter; 120,000 miles, 2nd owner
Old Yesterday, 02:38 AM
Quote:
No problem, thanks David
__________________
1942 GMC 6x4
Old Yesterday, 04:13 AM
KsCop's Avatar
Jim
Got rid of the feedback carburetor, computer, air pump and EGR a while ago. DUI distributor and basic Carter YFA. It runs great, just get the occasional run-on, usually in the warmer weather
__________________
2005 Chevy Uplander
Old Yesterday, 08:16 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Quote:
You have got the idle speed as low as you can? Another 100rpm lower may do it for you.
__________________
Dave F
1989 F250 XLT Diesel
Old Yesterday, 08:30 PM
KsCop's Avatar
Idle speed is as low as it can go and still idle OK. Everything has been done to this point, except for the solenoid.
It is an intermittent problem, but annoying. They put these solenoids on to correct just this issue, so I'll see how it does. Simple thing to try as I already have the bracket, the wiring is dead easy and the solenoid was only $14
I should know by Thursday..
__________________
2005 Chevy Uplander
Old Today, 04:08 PM
KsCop's Avatar
I posted an update in the 'What have you done to your truck today' thread, but just to 'close off' this one.
My solenoid arrived today and I got it installed.
I'm sure many know how these things work, but just to share for those that don't..
The idle stop solenoid actually replaces, or overrides the idle stop screw. When using this solenoid, you need to back out the idle stop screw so it no longer comes into play.
The solenoid is energized by KEY ON power and at that point, will extend to open up the throttle plate just a bit; just like the idle set screw does (or did). You need to adjust (turn in or out) the idle stop solenoid to set your idle speed.
Once the key is turned off, the solenoid de-energizes and retracts, allowing the throttle plate to snap all the way shut.
When using the idle screw, the plate stays open just a bit when the engine is shut down. Because of this, some fuel can get sucked in the engine after the ignition is shut off. If there are hot spots, it can cause dieseling or engine run-on.
The idea behind the idle stop solenoid (anti-dieseling solenoid) is that as soon as the key is turned off, the throttle plate closes all the way and will NOT allow fuel to get sucked in. No fuel, no run-on.
Pretty simple and, in my view, pretty slick solution. And guess what? It worked slicker than slick on my truck. The run-on issue is intermittent, but with the solenoid in place I can already tell a difference; engine shut down is positive. It might be too early to say but I think it fixed the problem.
Not bad for $14. (I had the bracket or it would have been a few more $$)
__________________
2005 Chevy Uplander
Old Today, 04:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Carburetor part needed - help! 1986F150six Ford Inline Six, 200, 250, 4.9L / 300 4 08-20-2014 10:36 AM
1985 4.9 F150 Engine Run-On (Dieseling) KsCop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 07-23-2014 10:10 PM
Idle Stop Solenoid & Dashpot F100Mann 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-23-2014 01:43 PM
Carter YFA Carburetor puzzle raven3 Ford Inline Six, 200, 250, 4.9L / 300 4 02-28-2014 12:33 AM
Carter YFA Carburetor hoses dslauri 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-27-2013 12:16 PM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
