1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
No airflow in front vents
Old 10-22-2014, 09:22 AM
nelsonwong11's Avatar
nelsonwong11
nelsonwong11 is offline
Been going through all threads and sites. Can't tell what the issue is.
2005 Navigator. So my rear vents blow cold and hot air just fine. Front is the issue. the windshield vents work fine. But the front and lower vents do not blow any air. Actually you can feel the tiniest air coming out like something is blocking it. When I change temp from cold to hot and vice versa, it works fine. Low to high speed works fine as well. Everything is pointing to (I think) the actuator. If so, is there 1 or 2 that I need to replace and where. Also how hard is it. Rather not pay the dealership $$$$. Any instructions or links to other threads that have resolved this would be great.
Thanks.
Old 10-22-2014, 02:55 PM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
That sounds like a vacuum leak, the default outlet position in the event of a leak is the defroster. One typical place for that to happen is where the vacuum lines go under the battery tray.
Old 10-25-2014, 12:12 AM
leogla's Avatar
leogla
leogla is offline
Thanks.
got the same issue, and no luck finding the problem. Hate pay $$$ for this
Old 10-25-2014, 03:31 PM
alwaysfords41
Well then my advice is the same.
Old 10-26-2014, 12:00 PM
alloro's Avatar
alloro
alloro is online now
Received 4,194 Likes on 2,430 Posts
I second that. Look for the broke vacuum line behind the battery.
Old 11-14-2014, 05:35 PM
nelsonwong11
Thanks for the advice. I haven't had a chance to look yet but will try this weekend. So to make sure , I need to disconnect the battery, remove the tray, and look for loose or broken vacuum line(s). Is it one or more than one that could be broken? I assume I am just looking for some black tube. Anybody have a link to a diagram or picture of what I am looking for?
Do I need to do anything special to disconnect the batter (besides taking off negative first, then positive)?
Never done this before so sorry for the dumb questions.
Old 11-14-2014, 08:25 PM
alloro's Avatar
alloro
You shouldn't have to remove the battery unless it ends up being in the way if you find something to repair.
Old 11-15-2014, 12:35 PM
nelsonwong11
I'm not going to lie, I have no idea what to look for. I checked for obvious loose tubes and/or cracked tubes, but nothing stood out. I even turned on the engine and the heat/ac to see if air was blowing out somewhere under the hood but also nothing. I assumed the tubes I should be tracing are the black rubber ones with the black mesh coverings. Whats the best way to find this leak?
Old 11-15-2014, 05:52 PM
alloro's Avatar
alloro
Here is a thread that has a picture of the broken HVAC under the battery.
https://www.ford-trucks.com/forums/8...ml#post7787498
The following users liked this post:
Dan_T
1997 - 2003 F150
03-09-2014 11:26 AM
bob1987f
23
08-01-2007 07:53 PM
patrickemb
03-27-2006 11:43 PM
valleyd01
06-09-2005 02:04 AM
Blitz5
08-17-2004 12:24 PM
Quick Reply: No airflow in front vents
