1956 spendle arm & tie rod
The passenger side is not removable IIRC, you'll need the entire spindle. You'd be better off ordering a new HD tie rod from Mid Fifty, they aren't expensive and a lot stronger for use with PS and wide tires than the OEM ones. If you go with a set of used spindles, you should have the king pin bores rebushed and reamed before installing them.
I just called midfifties yesterday about these parts and was told you have none in stock. I've been trying to get this figured out all week but it's hard when the previous owner has thrown everything away.
This is everything I'm looking for.
Toyota 400 steering box kit
drag link
spindle arms
tie rod for drop axle and ends
3" drop axle
King pin bushings
If I can get basically everything from the box to the spindles, I would be a happy man. It is actually a simple system. It's just hard when you are going from nothing.
drag link
spindle arms
3" drop axle
King pin bushings
TAAA-3130-A .. Right Spindle Arm / Obsolete
1953/56 F100/250.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
TAAA-3134-A .. Left Spindle Arm / Obsolete
1953/56 F100/250.
No Ford dealer or obsolete parts vendor has any.
C1UZ-3A130-A (replaced A0AZ-3A130-A & 11A-3289-A) .. Right Tie Rod End / Obsolete
1948/52 F1/F2 / 1953/64 F100/250 / 1961/63 Econoline.
WESLEY OBSOLETE PARTS in Liberty KY has 10 = 606-787-5293.
C1UZ-3A131-A (replaced A0AZ-3A131-A & 11A-3290-A) .. Left Tie Rod End / Obsolete
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
WESLEY OBSOLETE PARTS has 7.
TAAA-3281-A (replaced TAAA-3283-A) .. Spindle Connecting Rod / Obsolete
1953/56 F100/250.
GREEN SALES CO. has 2.
2) B4C-3287-A .. Spindle Connecting Rod Clamp / Obsolete
1953/56 F100/250.
BOWMAN SALES & SERVICE in Bowman ND has 9 = 701-523-3257.
niko20
01-28-2019 01:52 PM
beartracks
09-17-2008 02:33 PM
MattyKappy
04-18-2008 10:49 AM
zstyle01
05-03-2007 09:03 AM
