Monte's 07 Expedition Build Thread
#152
#153
#157
I need an honest opinion, I had a few people at work today say they love the rims but they think if the tan part was red it would look much better. What is everyone's thoughts on this? I like the way it looks now but I can decide if I eventually want to reprint the tan to red.
#158
Gents, does anyone know of a documented process to change out the manifolds on these trucks? The ticking on the passenger side is getting louder and i doubt i will pass inspection now. I'm going to get some headers to replace the manifolds but i am debating on if i want to attempt it myself or not.
#160
#161
Hey guys, when i turn on the rear vents when changing temperatures i can hear i think the blender door making a tapping noise as if the door is trying to move then fails and falls down. I have been looking it up and there's not much on this but i think there's two blender motors correct? Also which one needs to be changed?
#162
There are two, tons of info on it here if you search blend door actuator. They are both behind the same trim panel - passenger side quarter molding. If you pull the change tray on the top of the hump, the floor to ceiling one is right there, just slightly forward of the opening. The temp one is down on the side of the wheel well arch. Some report being able to do this swap without taking the whole panel off by using the access through the change tray and the second row cup holder.
#164
#165
So i had an idea this morning, the viper alarm (MOdel#: 5904V) in my F250 can support two vehicles and it would be nice to be able to consolidate my keys on to one key chain and basically just flip the remote between each truck. Does anyone know if the Viper alarms as long as they are the same type of alarm not necessarily the same model if the remotes will work across both vehicles?
I only ask because i need the key bypass in the expedition in order for it to work whereas the F250 doesn't need it.
