Am Broken Down In a parking lot need help bad
And check your degas tank for a crack that could leak into the sensor. A bunch of these sensors are tied together including the gas pedal, and if one shorts to ground, it will show a failure of the 3 gas pedal circuits, which will cause a forced idle so your truck doesn't go all Toyota on you.
At least we are not full drive by wire "yet"
Sean
I'm glad that you found the problem but I would not have had the knowledge to pass along to you if it weren't for the veterans on here who taught me that same trick. I have an early build so my EBP sensor is a lot easier to get at than the ICP sensor so even though it was my ICP it was suggested that I start with the EBP so since you had tried the ICP I only passed along what I had learned on this site.
I found the issue to actually be in the pigtail itself going to the ICP so I replaced both ICP and EBP pigtails as well as the ICP sensor itself and no more VREF problems.
jgilrfr
13
10-16-2010 02:32 AM
