Please Help
Please Help
I bought an 86 f150 its a beater good deal at a bad time my wonderful machine was stolen and I need wheels. Any was on the way home I was on the highway and I lost power (not electrical) and I couldnt get past 50 now truck has no accept takes forever to get to speed but idles ok sorry my truck is a Ford F 150 1986 inline 6once she gets warmed up she idles greatbut once you put a load on ur and drop it into gear she barely goestakes forever to get up to speed my max speed is like 45 she backfiresI've also noticed if I have the pedal pushed down a certain spot will go a lot better but anywhere after or before that it bugs out
iamthebat,
Welcome to the forum!
Many, on this forum, are older guys who do not readily respond to posts which are written quickly, leaving out key details.
Please go back over your post and fill in the blanks, such as engine type, fuel injected or carbureted, etc.
There is a lot of knowledge available here, just help out on your end.
Get back to us!
Get back to us!
Holy crap this was hard to read. Learn some English.
I bought an '86 F150. It's a beater but I got a good deal during a bad time. My wonderful machine was stolen and I needed wheels. Anyway, on the way home, I was on the highway and my engine lost power. I couldn't get past 50mph. Now the truck takes forever to get up to speed but it seems to idle okay once it's warmed up. My max speed is now about 45mph and then it starts backfiring. I've also noticed that if I have the gas pedal pushed down to a certain sweet spot the truck will go a lot better but anywhere before or after that one spot the truck will bug out.
Heya iamthebat,
Welcome to the forum.
As a friendly heads up, please take note that if you want help from others, you need to make it easy for them to help you. Many (who very well may have the answer you need) will simply pass on your post because they don't want to go through the work of figuring out what you're trying to say. A little effort in your writing can go a long way.
Either way, have you checked the timing on the engine?
Look around the engine bay to see if maybe a vacuum line disconnected.
Also, pull out your spark plugs and see what color they are.
A quick diagnosis can help us point you in the right direction.
Shadow944795
05-16-2015 06:01 PM
erik_bishop
07-31-2006 06:11 PM
