HELP!! No Crank!!
HELP!! No Crank!!
I took my ECU out of the truck to other day to get the codes off of it to try and get it tuned. I got what I needed off of it and re-installed it. Now the truck will not crank. I put the key in, dash comes on, radio, locks, etc all work. But when I turn to key to start the truck, nothing happens. Starter does not engage, starter relay does not click. I checked the large connector on the ECU to be sure it is tight and seems to be. Did I bump something or accidentally mess with something that could cause this? next to the ECU on the inside of the drivers kick panel there was a small rely what does it do?
1992 Ford F350 460 E4od 2wd dually
UncleRock
02-24-2013 07:34 PM
89coal-mkr
11-09-2012 07:54 AM
