OEM brake controller vs prodigy?
I just got a '15 F250 6.7 crew cab XL with trailer package but no brake controller. I can add the brake controller unit, or I can install the Prodigy P3 that I used in my last truck.
Is the OEM brake controller as good as the prodigy? Should I install it and sell the prodigy?
It's an XL model and the brake controller was optional. The trailering package adds the wiring so you can hook up your own brake controller. If it comes with the OEM brake controller already installed then it was added as an option by the factory. The truck came with the pigtail used to connect an aftermarket brake controller so hooking up my prodigy would be a simple task.
I checked and adding the OEM brake controller requires the dealer to "flash" that feature into the ECU.. so I'll have to make a trip to the dealership.
It did come with the towing mirrors. Not the electrically folding and telescoping ones, but the ones you manually fold and pull out.
