Front End Squeak Noise When Moving
Crystal
Have you ever mentioned the sound to your dealer, Lastwagen? If not, I'd recommend that as a next step. I can help out by looping in your regional customer service manager. If that's something you'd be interested in, PM me your full name, best daytime phone number, VIN, current mileage, and preferred servicing dealership. I'll do the rest.
Crystal
Crystal
Crystal
That's it! Sounds like the same thing mine was doing. They just greased some seal (I think it was a drive shaft seal, but not completely sure) and it took care of it. The dealers know about it.
QUOTE=Lastwagen;15760477]Mine does a "kwirp-kwirp" sound in the mornings. Seems to be about the frequency of the driveshaft rotation. I'm at 15k now and it's done it since new.[/QUOTE]
Good information. After recently buying my 2014 F350, I heard the same kind of sound at slow speeds a couple times as I passed through the gate to the USCG base I work on. I was thinking hub, knuckle, or u-joints on front drive shaft. I had a nagging thought that made me check the position of the hub selection, and low-and-behold, the selling dealership left the hubs locked after performing the 172 point Ford Certified Pre-Owned checks. Then I drove it about 500 miles on dry pavement afterwards.
Local dealer (not selling dealer) will conduct a check next week to make sure hubs and the rest are in good shape, but I will also mention lubing the transfer case seal & the bulletin.
Crystal
Sorry for the highjack OP.
Thank you Crystal. I just passed 14k on the odo. FYI, I am also asking them to identify and cure excessive wind noise coming from the windshield. Once I hit 45mph the noise kicks in, and by the time I get to 55, it sounds like I'm bucking a 50mph head wind. I've read this is not an uncommon problem found by others unfortunately, and it's often related to improper sealing of the windshield or a molding problem...
Crystal
Crystal
This is the exact noise I have on my '15 and I also had it on my '12. on My 2012 I actually saw that the tail shaft seal was dry rotted, had the dealer replace it and fixed. My 2015 started to do the same, its most prevalent early in the morning when its colder....when I had it in for service I told the writer to inspect and tail shaft seal. He said the tech said it looked fine but I don't trust it since it was most likely a $15 hour lube tech that left oily hand print smudges on my grill and door panel. I don't have time to drop the truck off again for this just to inspect. I will crawl under the truck and lube it up if its not dry rotted. If it is then I will have to bring it in to replace the seal.
15,000 miles. They found the squeak but wanted to keep it overnight to tear it apart. I rescheduled it for Monday because I can't be without the truck this weekend.
#29
Crystal
#30
Crystal I wasn't ignoring your offer I have been out of pocket. You all have described my problem to a T. Now with the weather getting wet is really prevalent. I any one gets the correct bulleting number and or what grease they are using it would be great. I cant get mine in for a while and when I talked to the dealer they could not find any reference in their search. I just turned 14k and it has been with me since new also.
