On my 71, I was always looking for the air breather setup that came with my Straight-6. Well most of the stuff was already on my "new" 69, except the proper heat riser tube from the exhaust manifold to the breather. I am using a piece of flex hose, which is fine.
But I would kind of like to have it the way I think it is supposed to be.
Ran across the pictured items when searching for a Carter YF carb for the 69.
The seller posted it has Carter YF air breather and filter.
Seller did not do himself any favors with his listing this as Carter YF air breather instead of Ford F100 air breather.
I'm wanting to add the riser to mine if I can find the parts at the pick n pull. all i need is the lower parts i think. That is if I understand how the system works.
I searched high and low for the riser and for the part that attaches under the manifold. Never did, until now. At least you can get by with a flex tube connection.
On my 71, the muffler shop welded a 2-inch piece of pipe to my exhaust manifold to allow me to connect a hose from there to my breather to allow it to pass inspection.
This ebay score will not work with my 240. wrong shape for riser (which I don't have) and the part attaching to the engine (which I do have) will not work.
Back to the flex hose. Was really hoping to get under the hood to stock.
