My Turn! 06 E350 6.0 missing, rough runing
Old 10-20-2014, 08:10 PM
mohoneywell's Avatar
mohoneywell
mohoneywell is offline
Hey all, reading up on what to expect, but figured I'd start a thread so i can get answers.
2006 E350 6.0 167,XXX Van
Stock truck, always has been- no Major work done to my knowledge( I saw 38 pages of service history @ ford dealer where I purchased used- showed diligent 6.0 service history and good general care taken, no major issues)
500 miles on oil change(blue rotella)+ archoil
500 miles on fuel filters- some slight indication of possible tank delam, but nothing serious.
I buy fuel @high volume station
started and ran great this morning, 25 minute drive.
parked and sat for about half hour
started up and had slight miss. drove back home,
on highway -stuttering at 1900-2300rpms, get on it and she goes fine, has boost pressures up to high teens anyways. 2 stops in route, got worse and worse running. did not notice any smoke.
by the time i got it into the garage, she barely chugs off the line. missing bad.
I do have a Scangauge, but dont have all the "right" xgauges installed yet to troubleshoot this.
Temp deltas have always been good.
I do have 47.6-48+ volts FMP, and she builds boost.
looks like i need to add a few gauges, I do have the great PDF list and knowledge to install, but what do I need to look for?
Thanks for the help!
Old 10-20-2014, 08:13 PM
CPB1's Avatar
CPB1
CPB1 is offline
Scan for codes?
Old 10-20-2014, 08:15 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Any DTCs? Fuel Pressure?
Old 10-20-2014, 08:40 PM
78fordman's Avatar
78fordman
78fordman is offline
Can you do a bubble test on the e series?
Old 10-20-2014, 08:45 PM
mohoneywell
the scangauge shows no codes...
I havent done a DTC count yet
Old 10-21-2014, 10:28 AM
mohoneywell
Ok, loaded up some more xgauges.
cold start this morning was good, seems like normal. Warmed up a little and started missing.
measured on a "cool" engine
DTC= 1
Gauge KOEO idle 2500
VLT 12.0 13.6 UP TO 14.1
MAP 14.3 14.4 19.9-20.3
EBP 14.3 18.1 29.3
BAR 14.3 ------------
ICP 7 815 1556
ICV .24 1.06 1.9
FMP 48 48 47.5
Old 10-21-2014, 10:33 AM
mohoneywell
also note that I use motorcraft filters.
drained clean diesel from bowl yesterday.
the bubble test- you mean pulling secondary filter and watching for aerated fuel? PITA, but probably doable with a mirror.
Old 10-21-2014, 11:15 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Need a contribution test.
Josh
Old 10-21-2014, 04:40 PM
mohoneywell
Contribution Test.
Hmmm.
I just got in touch with a friend who works at a medium duty truck shop.
They have a Snap-on and OTC scanners which he said will pull DTC's, and one of em would do a buzz test.
Anyone know if I can do contribution test with one of these scanners?
I will do some more research and see what I can get done with the scanner tomorrow.
Thanks
Old 10-21-2014, 05:18 PM
Bullitt390's Avatar
Bullitt390
Ford IDS is the only true contribution test with the ability to go manual/ non-compensated and turn off injectors.
AE does a low resolution contribution test.
Josh
Old 10-21-2014, 05:22 PM
BryanStein's Avatar
BryanStein
BryanStein is offline
DTC= 1
EBP 14.3 18.1 29.3
ICP 7 815 1556
ICV .24 1.06 1.9
FMP 48 48 47.5
So you're getting 6 psi of boost at 2500 rpm without a load? As I recall from memory, that's a little high without a load? Then again, this is on a cold engine.
If you get the same results at operating temps, check the following sensors and wiring. Clean if dirty. Use a weed eater wire (or similar) to clean out tubing.
EBP
MAP
IAT2
BAR
Also check the VGT % and report.
Do you still have your EGR valve? Could it be sticking open?
Old 10-21-2014, 05:45 PM
mohoneywell
EGR valve is still intact.
I suppose that I should pull and clean sensors first, before I go and take it in?
Talking to my buddy, he says their Snap-on will do buzz tests and cylinder cut outs, as well as pull the codes.
Old 10-23-2014, 08:29 AM
mohoneywell
Boyer Trucks will do contribution test @ $125.
I may run it up there shortly.
assuming Injector-
whom is a good reliable source?
what else should be done?
how bad is it on a van body????- there is not much room in there....
Old 10-23-2014, 01:22 PM
mohoneywell
okay, couple more numbers-
VGT- 0, 0, 55 PEAK
EVM- 0, 0, 0
cool engine.
gonna have to take for a drive and see how she acts.
exhaust is clean, but smells like diesel...
cleaned EBP tube.
Old 10-23-2014, 09:01 PM
BryanStein's Avatar
BryanStein
VGT- 0, 0, 55 PEAK
EVM- 0, 0, 0
cool engine.
cleaned EBP tube.
It's your high idle (2500 rpm) boost still high? It should be about 1 or 2.
Quick Reply: My Turn! 06 E350 6.0 missing, rough runing
