transmission problem
Old 10-20-2014, 07:21 PM
85MD's Avatar
85MD
85MD is offline
I am not sure what the problem is, but here goes the best explanation I can manage. When driving the truck at say about 30-40 mph, and just barely pushing on the gas, the truck will jerk almost as if the transmission is trying to switch back and forth from OD to the lower gear. If I disengage the OD, rpms go up and it stops. If I reengage the OD, it starts again. If I accelerate, it doesn't happen. It doesn't happen at low speeds or higher speeds than about 45 or so (from my recollection). So lets say I get up to about 35-40 mph, stop pushing the gas, then ever so slightly push the gas, it starts again. This problem is relatively new, starting months ago. By the way, I have a 2004 F150 Lariat 4x4 triton 5.4 towing package
thanks for the help..
Paul
Old 10-20-2014, 09:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,571 Likes on 1,049 Posts
It is almost certainly a bad ignition coil. I've fixed many of these with identical symptoms.
Old 10-21-2014, 08:39 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Its either a coil or a plug with carbon tracks. Find out which cylinder it is and replace the coil and plug on that cylinder then replace the rest of the plugs and coil boots.
aquaholic
2004 - 2008 F150
18
09-12-2023 11:30 AM
blueoval65
2004 - 2008 F150
03-18-2015 07:58 PM
Tennessee Toy
2004 - 2008 F150
13
09-05-2012 03:45 PM
funat420
1997 - 2003 F150
01-09-2010 06:55 PM
Quick Reply: transmission problem
