1991 f150 headlight removal
I don't know if the '91s are the same as my '97, but from what Fastback is saying it sounds like my '97. On mine the two nuts are 7/16" or 11 mm (7/16" seems to fit best). And I used a much shorter extension, or just a deep socket. But again, mines the newer front end so I'm not sure it's the same.
I did find this diagram that shows the location of the bolts holding the headlight on for a 91. I hope this helps
on
Or just use a short extension. Works fine without having to remove other stuff. Yes, without the battery and reservoir it would be easier, but not enough in my opinion to warrant the extra work.
78 PEB
12-25-2015 02:27 PM
tennman47
01-29-2007 10:46 PM
