Help diagnosing a stalling 4.9?
Background, had a battery die on me at work for some reason. Replaced battery and truck ran fine for about a day. Then it randomly started stalling out on me. Ive checked and the new battery is perfectly fine. I then went ahead and replaced plugs and the fuel filter. Still having same issue. I tried to pull EEC codes and all I get is a solid check engine light.
So now I am stumped on how to diagnose further. When I turn the key to on I hear the fuel pumps come on. I can two foot drive it now but it hesitates like its not getting enough fuel.
Is it a failed EEC? PCM? EGR valve? Fuel Pump?
Any help would be very much appreciated you guys always save my butt before.
Not the usually flashing like its showing codes.
You can take it to an electronics shop to see if they can replace the capacitors for you. It is a medium skill level repair if you want to try doing it yourself.
If you go down the path to order a rebuilt one, there are no new ones, they go by the part number listed on the PCM. It starts off with something like E9ZA-12A650-AA. Some suppliers will simply use E9ZA-AA. The prefix and suffix will change but the middle 12A650 will always remain the same.
This place can repair the one you have: Ecu Repair Now, automotive circuit board testing and repair
monarokid
02-05-2007 11:04 AM
ford5.8
25
12-08-2004 10:37 PM
