Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Terminator and t56 swap into 56 f100
Old 10-19-2014, 03:15 PM
FastFred68 FastFred68 is offline
FastFred68 is starting off with a positive reputation.
Hi, I'm in the planning phase of this swap. I'm wondering if anyone else has done it? I've seen mid motors swapped but not the terminator. I have questions on fuel delivery, headers, and fitting the huge motor around my steering.
Thanks, Fred
Old 10-19-2014, 07:31 PM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed is a splendid one to beholdCharlieLed is a splendid one to beholdCharlieLed is a splendid one to beholdCharlieLed is a splendid one to beholdCharlieLed is a splendid one to beholdCharlieLed is a splendid one to behold
Check out Steve Stillwell's 56 F100...google it or contact him at TCI where he works in sales.
Old 10-19-2014, 08:20 PM
[QUOTE=CharlieLed;14754653]Check out Steve Stillwell's 56 F100...google it or contact him at TCI where he works in sales.[/QUOTE
Thanks, I'll check it out
Old 10-20-2014, 05:01 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
I've got a CSB 400 and T56 in my 56 panel. It's a long tranny so you'll need bucket seats as the shifter would be under a bench seat. Where did you get a Terminator motor and what do you plan on using the truck for?
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Old 10-20-2014, 07:18 AM
Hi, I got the engine, trans etc, from a wrecked 2004 cobra. The truck will be mostly a cruiser with some drag strip duty. What did you do for a clutch pedal? My motor is supposed to show up next week, but from what I've read it's cable operated?
Old 10-20-2014, 12:10 PM
AXracer's Avatar
Chuck Frank
My T56 clutch is hydraulic with an external slave cylinder. The trans is from a 92 Camaro so I modified and adapted a pedal set from that make and model vehicle along with the matching clutch and brake MC. Since the 56 steering column exits thru the floor rather than firewall above pedal mount like modern vehicles my pedal mount needed to be modified to separate the two pedals so they straddled the column.
What front suspension, steering are you planning to use? You do know the stock 56 chassis is flexible which is OK for street use/moderate HP but not very suitable for drag race use with high HP and slicks without significant modification.
__________________
Old 10-20-2014, 12:52 PM
Thanks for getting back to me AXracer. My truck has been heavily modified. I took it down to the bare frame and cut off everything that wasn't needed. I then boxed the front end of it and installed a tci mustang2 and a tci 4-link out back on an explorer 8.8 rear. I have power rack and pinion, power 4 wheel discs and 20" gt500 wheels all the way around. It would be easier to use the gm t56 because of the hydraulic slave. I have done that swap with an ls3 in my 68 vette. The problem with the ford t56 is the cable actuated pedal. I see tci makes a dual underfloor pedal with brake booster and hydraulic clutch. Maybe I can adapt the f body throw out bearing to work on my t56? I might also have to adapt the cobras hydro boost as we'll. I looked at your photos, did you just fab a bracket under the dash for your clutch pedal?
Old 10-20-2014, 04:03 PM
AXracer's Avatar
Chuck Frank
A PO installed the tranny and a strange pedal setup with a hanging aftermarket clutch pedal using the original 56 brake MC on the firewall for the clutch and the original underfloor brake pedal with a new non boosted dual circuit brake MC under the floor!?!?
It worked but it was a little strange feeling driving it. I used a combination of the Camaro pedals, with the unique plastic OEM Camaro clutch MC, and the Camaro brake MC with a dual diaphragm booster mounted on the firewall. The pedal bracket was made by combining the Camaro bracket with the ? clutch pedal bracket to spread the pedals.
__________________
Old 10-20-2014, 04:19 PM
Yeah it looks like I have a major project ahead of me. I may try to get the factory hydraboost from the mustang in there as well. I didn't think about how for back the shifter was. I just had my bench seat redone...
Old 10-22-2014, 09:46 PM
mustangmike6996's Avatar
mustangmike6996 mustangmike6996 is offline
mustangmike6996 is starting off with a positive reputation.
Quote:
I think its really 6 one way and a half dozen the other way....
The power steering rack should work ok with your pump but you will need custom lines (would've needed them most likely anyway)
the hydroboost fab work at the firewall wont be terrible but, as mentioned above, you will need to fab up the pedals.
I have seen a few companies offer the 48-52 style brake master cyl/power booster support with provisions for a clutch master cyl. There are plenty of hydraulic t.o. bearing kits that are universal. Is the F100 brake system under the floorpans as well?
I think you might be further ahead to mock your engine/trans up, see how much room you have next to and on top of the massive 4.6's cam cover. That might put your hydroboost unit too far off center to do anything decent with pedals.
Again, anything can be done, just depends how much time and money you want to spend to do it.
__________________
2013 F150 Eco
1969 Mustang Fastback 331 4-speed, needs paint
1951 F1 4.6L DOHC, Tr3650, 8.8
Gone- 96 Stang, 06 Stang, 10 Stang, 08 F150, 04 HD F250, 10 Raptor (I enjoy cars/trucks too much)
Old 10-23-2014, 07:48 AM
One issue I'll have with the pedals is the fact that the steering column will run right through the middle of them. I currently am running my brakes under the floor. I have seen a combo under floor brake and clutch master, and it was the route I was planning on going until I saw the mustang used the cable set up. Ive been looking for any info on using a full hydraulic setup, but I haven't found a thing. Maybe I should get ahold of McLeod and see if the have a t/o bearing I can use. I will be getting the motor and trans mocked up ASAP, if you look under the hood of the cobra it fits the hydro in a tight spot also. I'm still waiting for my engine to show up, and then i can see what I'm up against.
Old 10-24-2014, 02:48 PM
What wiring harness? Dunn right or telorvac? I saw on trucks that the Dunn right works with the stock harness and only requires a 4 wire hook up.
Old 10-27-2014, 01:32 AM
has anyone done the hydraulic clutch conversion on their cobra? - Page 3
Not a ton of help but that should get you pointed in the right direction.
I know that Modern Driveline makes direct swap kits for the T5s from linkage to hyd with the TO bearing. Its not a huge deal, You just need the TO bearing and a slave cylinder to pressurize it. Maybe look into the newer style S197 bearings and master cyl. It probably wont work but the master cyl and res. were all one piece if I remember correctly.
__________________
2013 F150 Eco
Old 10-28-2014, 08:50 PM
http://www.ford-trucks.com/forums/13...mod-build.html
Also, there is a hyd. clutch setup about 1/2 way down this build page.
__________________
2013 F150 Eco
Old 11-15-2014, 08:16 AM
Well I started on the swap yesterday. I removed the front clip, and started disconnecting the engine.
Click the image to open in full size.
On the way to my buddies shop
The tear down
Similar Threads
56 Fred's 56Fred 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 01-06-2013 12:46 PM
Horn for 1966 F100 Custom Cab ffillah WTB - Parts & other 9 10-03-2012 11:31 AM
carfax wicked5ltr Car/truck Buying Advice 1 01-30-2008 07:44 PM
Hello fredsjdb New Member Introductions 2 09-24-2006 07:08 PM
Buying a boat nymo General NON-Automotive Conversation 11 06-22-2005 10:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
