thanks. When I bought the truck I could not find reverse. Lol, I kept looking to the right and down. I am old enough to have driven this tranny but that's what happens in life, CRS disease !
ND, thanks, I am out of town from the truck. I just bought this truck in Idaho, and trailered it home 1k miles. It a real barn find, and I will be posting pictures when I get home.
You never know what a previous owner has done to the truck. Most likely a T18 if I had to bet on it. But just throwing out another possibility.
The only way the OP's '69 F250 could have a T-98 is .. if a 223/262 I-6 or 292 was swapped in. The last year for these 3 engines and the T-98 was 1964.
Why not a 352-360 or 390? I had the T98 behind a 390 when I first got my 64. and later behind a 360 that I pulled from my 71 when the 390 gave out. Obviously the 390 was swapped in my 64 since they weren't a factory engine option in 64.
Very interesting Bill. The pic above is the trans I pulled from my 64 when I got it. I put the 360 that was in my 71 in the 64. I reused the clutch assembly that was mated to the t98 since the np435 that was in the 71 clutch had a different spline disc. Not sure how it worked if you and Garbz both say it won't work. The bellhousing had the 2 ears on the side to bolt to the crossmember.
2 ears:
C5TZ-7505-C .. 352 Bell Housing / Marked: C5TA-7505-C
1965 F100/250 4WD - 1965/66 F350 - 1966 F250 4WD
These trucks use the same engine/trans mounting system as 1961/64 292's.
No ears:
D0TZ-7505-A (replaced C5TZ-7505-B) .. FE Bell Housing / Marked: C5TA-7505-B
