Powertrain Shake - it's not an energy drink.
You said it hits at about 1800 RPM's in all gears. What about sitting still? Have you tried running the RPM's up in neutral? I'm inclined to think the problem is in either the motor or tranny. Speed related is usually driveline, wheel end, or tires. RPM related is something different. Motor mounts, harmonic balancer, fan clutch or air compressor?
- Neutral @1800 RPM - subtle, but there... half the time.
- Cruising @1800 RPM - Annoyingly there (about 15 min up to 1 hour), then subtle, then annoying.
- Accelerating - unsure, this never lasts long enough to sort out.
- Decelerating @1800 RPM - the one clear and obvious symptom, even when the FIPW shuts the fuel off.
- 2nd gear @1800 RPM - shaking, but without the TC locked... so it's subtler.
- 3rd gear @1800 RPM no TCLU - softer shake than second gear.
- 3rd gear @1800 RPM with TCLU - this one's the strongest, particularly in decel.
I spotted that and that's one test I can do after I've eliminated some other stuff (no water pump or alternator when I try it). I'd like to thank FiznUKa for the idea, and you for reminding me... because my head is full of stuff that makes me forget things.
I thought I already looked, but I'll double-check it.
365 to 380 PSI dead cold... but that was then, things could have changed. What disturbs me is the coming and going of the symptoms. I don't fathom how the engine shakes one time, but not the next (the harmonic balancer is my only hope for sanity at this time) - with no link to engine/transmission/outside temperatures. I think I know the answer, but can compression loss bring that? Will U-joints come and go?
I ask this like it's all just one problem, but I can't yet rule out the possibility of more than one problem leapfrogging over each other.
If you can feel it sitting still and reviving the motor up, leads me to think it in the front of the motor. Perhaps a loose fan, a loose fan clutch, the power steering pump, or the A/C. Engine RPM's have more to do with the vibration rather than driveshaft does. I guess even the alternator could cause it.
It took me a year to figure out the vibration in my 08 work truck. Mine was self induced. I installed a set of centramatic wheel balancers and the ones on the front actually made the truck vibrate. And the whole time I thought it was in the rear of the truck.
subford
05-31-2007 08:44 PM
