new stc still no hot start
Old 10-18-2014, 06:03 PM
cookingguy's Avatar
cookingguy
cookingguy is offline
So replaced the stc got it all back together and still no hot start. My scg2 readings these are all when the engine is up to temp the ficm is 47.5 icp 251-266 ipr is 84.71 also I have a brand new icp installed. When I did the stc I did the o rings that came in the kit
Old 10-18-2014, 06:20 PM
69cj's Avatar
69cj
69cj is offline
What are the icp readings when cranking?
Old 10-18-2014, 06:32 PM
cookingguy's Avatar
cookingguy
All those readings are when the engine is all warmed up and I am cranking. What really sucks is I have not even made my second truck payment yet. I am really starting to regret not getting a Chevy or dodge. But I really liked the way the ford drove and the interior over all the others in my price range.
Old 10-18-2014, 06:42 PM
69cj's Avatar
69cj
69cj is offline
Sorry, missed the icp reading. Try unplugging the icp and see if it starts. Icp needs to be at least 500 psi.
Old 10-18-2014, 06:45 PM
cookingguy's Avatar
cookingguy
Did that and still no love. Am I looking at the hpop
Old 10-18-2014, 07:53 PM
bismic's Avatar
bismic
bismic is online now
Received 2,478 Likes on 1,718 Posts
original dummy plugs?
Old 10-18-2014, 07:59 PM
cookingguy's Avatar
cookingguy
Unknown. But I am thinking so the stc looked original and the truck has about 198,000 on it.
Old 10-18-2014, 08:50 PM
tonefordays's Avatar
tonefordays
tonefordays is offline
That was my first guess too. Same thing happened to my truck back in April. I replaced the STC with the new updated one, and still had the intermittent no start when hot. I ended up having to also replace the standpipes. Runs good now.
If it's starting up for you when it's cold, I would expect the HPOP is working fine. I would suspect the standpipes/dummy plugs.
Old 10-18-2014, 09:14 PM
cookingguy's Avatar
cookingguy
Well I quess I will going back in in the near future with standpipes and dummy plugs
Old 10-19-2014, 09:47 AM
BryanStein's Avatar
BryanStein
BryanStein is offline
In that model (updated hpop), there's really no reason to do the stc without also doing the stand pipes and dummy plugs. On the bright side, you've done the hard part already, and that hpop rarely has a problem.
With that many miles, you should consider an air test on the hpo system to validate the dps and sps are leaking, and not an injector or two.
Old 10-19-2014, 02:09 PM
cookingguy's Avatar
cookingguy
I will be doing an air test In a couple weeks since I have to go back up to Frisco from la and the truck will be staying home. It was at a shop a few weeks back for the same problem thr shop says he did an air test and ended up replacing two injectors and some o rings then the problem started again about a week later
Old 10-19-2014, 03:57 PM
BryanStein's Avatar
BryanStein
Well, in that case you could be looking at ball tube (nipple cup) oring issues if the same injector orings are bad now.
Old 10-19-2014, 04:13 PM
cookingguy's Avatar
cookingguy
Is that a big job to replace
Old 10-19-2014, 04:17 PM
BryanStein's Avatar
BryanStein
Not much more than changing an injector. You just need a special tool and an oring set. You have to pull the oil rails.
It could be that the shop that installed the injectors didn't install the correctly.
Old 10-19-2014, 04:40 PM
cookingguy's Avatar
cookingguy
I have had such bad luck with shops I will not be taking my truck to any shops. I am very comfortable working on engines I am restoring my 79 jeep Cherokee and am in the midst of a full engine rebuild and swap on my 83 cj5 so I am not affrid of the work. What is the special tool I need so I can order it so I have it if needed.also can I get the o ring set from my local ford dealer ? Anybody got a part number
Quick Reply: new stc still no hot start
