1988 c6 belt adjustment bolt won't tighten
So I've been reading through these forums, and came across the tranny belt adjuster. My bolt adjuster will not tighten to 120lb/in. Unless I tighten the locking nut first. To my knowledge the locking nut must remain loose untill the adjusting bolt is torqued. Then the nut is then torqued to 35-45lb/in.
Please help.
Please help.
on
That bolt is engaged into a strut, and the strut is on the band as well as a hinge point I believe. It sounds like one of 3 possibilities, here goes.
1) band it cooked, and all material is worn or burned off thus leading to excessive clearance which will not allow for proper adjustment
2) strut is no longer in contact properly with band, adjusting screw, or case
3) Might not be a C6. Probably is but could be the E4od.
If it needs a band, it might be possible to cut the old one and roll in a new band without tearing the tranny down or removing it from the vehicle. if the strut is bad on the servo side, that might cause this problem as well good luck.
DBGrif91
06-10-2012 11:49 AM
