V10 Life Expectancy
V10 Life Expectancy
Well been driving my 147k 2003 V10 Limited for the past month and love this truck more than any vehicle I have driven the past 30+ years. My motor and transmission appear to function flawlessly and have been averaging 12.5 mpg on my daily commute.
Plan on keeping this one for a long time - with light use (I generally keep her under 2000 rpm and do not tow or haul any significant loads - how many miles can I expect from the original motor and transmission. I have always had great luck with Fords - had a 95 Taurus that went to 250k on the original drive train. Would definitely do a rebuild when necessary as the rest of the vehicle is rock solid...
Mine has 200K. I run full synthetic, change every 8K. Trans service about every 40K. The only issue I've had is 2 alternators and now I am tracing down a electrical drain somewhere. I'll be working on it again this afternoon and this is by far the most significant repair I have had to make. PITA
My 03 V10 has 194K. Replaced the alternator this year and I think I'm due for both transmission flush and injector cleaning. Up until 2 years ago it was averaging 16mpg on trips, 14 combination driving. Currently it's 14.5mpg hiway, 11.5 towing.
Since I drive more than 24K a year my main concern has been gas prices. I'm considering retiring the Ex to tow duty for shows and picking up something that gets in the mid to upper 20's for daily use. At more than $5000 year in gas in the Ex it's a move I need to make. I'll just miss the daily comfort of the Ex.
As long as you change the oil and don't overheat it you will wear out most everything else before the engine. Not that this will happen any time soon.
