parking brake issue?
I'm in the process of installing Fe eng with T-19 speed trans in my 53 F-600 pulled the good running flat head V8 and T98 trans. But I need to find a parking brake assembly to re-install
on the rear of the T-19 trans, or I need the out put shaft "Yoke" that would would allow me to mount the four bolt flange to the park brake drum. Can anybody help me with parts ideas, or suggestions?
I'm in the process of installing Fe eng with T-19 speed trans in my 53 F-600 pulled the good running flat head V8 and T98 trans. But I need to find a parking brake assembly to re-install on the rear of the T-19 trans, or I need the out put shaft "Yoke" that would would allow me to mount the four bolt flange to the park brake drum. Can anybody help me with parts ideas, or suggestions?
http://www.speedwaymotors.com/Pinion-Mounted-9-Inch-Ford-Emergency-Brake,44784.html
Hey!!!!! I've seen that truck.
https://www.ford-trucks.com/forums/1...-nebraska.html
I was in Lincoln this summer. My son went to Football and Baseball camps and this was on the route between my hotel and campus. I stopped by and took a bunch of pictures, but no one was there at the time.
Sorry I can't help with your issue. So what are your plans for the truck. When I was there I pondered how I could load my car up and drive the truck back home.
I saw this when I was looking at the Speedway Street Rod Catalogue today. It mounts to a 9" Ford Rear Axle pinion yoke but it looks like it could work on other axles with a little work.
Thats what I was going to say Our F650's highway dept that how they
are; you may check and look your town truck state trucks
F350moneypit
02-28-2017 08:43 PM
Scotty's 52 F3
10-29-2015 08:37 PM
hot-rod
04-12-2009 11:18 AM
