Headers for my 390 ci f600
So I just finished the motor for one of my f600s.. its a 390..nicely built for HD use..the truck is a 1974 bodystyle
I wonder if anyone has ever used headers...
I was thinking of using full length block huggers.. Sandersons..for example.. which are made for the light duty rigs..
Has anyone ever tried using headers on your HD truck?.. as people may know sourcing reasonably priced good quality cast iron manifolds is difficult at best
Thanks
Thanks
Header flanges are known to warp some over time. If you are going to have any high loads, i believe the headers will fall apart quickly at least the ones you can find for a 390 Truck.
X2 on that. The Med duty truck manifolds always are a lot bigger and flow better than those of the lighter truck manifolds on the same engine series ,...and this is all brands.
There are also dorman repos for the 390... but I doubt their quality.
I'd love a set of Shelby cast iron ones... but Im not wealthy... and excellent ones are Sky's the limit what the market will bear...
Thanks
I would generally agree... although a couple of good builders make heavy duty ones out of 14 gauge tubes...and 3/8" flanges...
Thanks
Thanks
Even when Ford put the 300 six in a F600 truck it got a bigger Exh manifold.
I doubt the Shelby manifolds would flow much more than the FT manifolds.
Here's a couple of pictures of what Im up against
Normal 390 pickup headers wont work ..I believe,, because of steering box clearance...
I then looked at blockhuggers and they MIGHT fit..
Passenger side should be no problem as there appears to be lots of room.. and even if there is starter clearance issues I can do a hi torque mini starter
Im looking at these
http://www.ebay.com/itm/301223465519?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
They are made out of 3/8 flanges..plenty tough for a truck
drivers side
pass side
motor in chassis.. still needs to go back that final inch.. and I cant do it by myself.. the wife is willing but you all know.. thats frustrating at best.. so Im waiting for a buddy to come and help me with the last inch.. always the hardest one...
Drivers side.. its tight I think but I wont know until I actually put one of the huggers in there.. I can change the clutch return spring by shortening it... that would give me an inch.. obviously the steering box is fixed
And pass side.. looks like there's plenty of room for many different exhaust types... of course starter may be an issue
4 x 4 headers dont work... my other options are limited
Im looking at these
drivers side
pass side
Yes... I have looked at flowtechs,,, the ones you posted . I think the drivers side doesn't kick forward enough at the rear most pipe ,... but I'll have to try a set first before the huggers, I would go full length if I could but I just don't think any will adapt and miss the Trans and cross member
Thanks for the suggestion
So I tried the flowtechs because the Oriellys guys are very good to me..and let me try the different versions with no hassle taking them back(of course I was careful to handle them nicely so the next guy doesnt get a scratched product)
I ordered all the ford 65-79 sets..
2 x 2 and 4 x 4
The 2 x 2 sets went right into the crossmember and went out the window right away
The light duty 4 x 4 set fit without a hassle using a mini starter on the passenger side.. A full size starter might work if I wanted to fuss with it,, but even if I got it in it wouldnt last under the heat so close,, the mini starters from summit are clockable as well.. putting the selenoid as far from the heat as possible.
The drivers side rear most tube touched the clutch cross bracket so you couldnt push the clutch in... they would work if remake the clutch crossover clearancing for the headers
The 12542flt 4 x 4 versions ended up nicely about 2 inches under the tranny crossmember.. perfect shot to the back
BUT.. and this is a killer.. the flowtechs are crappy made.. 5/16 flanges and 18 ga pipes... they wont last long even in the ceramic coated version... and I would still have to use something else so that I didnt violate warranty for break-in on the new engine
I really liked hedmans elite heavy duty series...3/8 flanges.. 14 ga tubes...heavy duty made for towing and motor homes... but they only come in the 2 wd version that puts the collecter square into the crossmember
I looked at hooker... sandersons... some of the smaller companies.. but no one makes a heavy duty version that seems to be a match.. at least not that I have found.. it needs to be the 4 x 4 version long tube.. it has a drop and a second drop... like the picture above
Im still open to suggestions.. Ill look at my ft manifold... they are in excellent condition.. Im not sure I understand closing off the port.. the best way how to accomplish that.. and if they wouldnt leak thereafter..
I have a set of dorman repo fe ones coming.. I can see they are way more restrictive and thats what I read in the fe ft exhaust bible article.. it may be the best compromise for me.. I can make a killer nice exhaust from there back...
Im still debating the shorty stainless univerals... Ive tried to take measurements off of the picture as none are available... looks like they potentialy might go into the steering box ..I cant tell.. it may be the case of buying them and then returning them kind of deal
Thanks
2 x 2 and 4 x 4
Thanks
I have a set of 406/427 cast iron longtube header in nice shape, I know they won't fit in an F100-350 with an FE (tried it)but never even thought of a medium duty chassis with the cab sitting higher on the chassis. I was building a 67 Mercury M700, but going to use a 98 F800 chassis now with a diesel. they aren't cheap but I do have a buddy with a 76 F600 we could test fit them on . they might outlast your engine if they fit.
Thanks
You have what looks like plenty of room for them(with the front engine mount),...in fact they are usually short and some times you can swap right side for left side to get a better outlet location as well.
I took some and posted them on a ford Website I frequent, I'll go have a look around. I've had them since 1984 ish, got them at Carlisle and carried them around a while
they have been in the rafters of the shed for many years.
I vote for FT manifolds, they dump in the middle- Y pipe Napa- is stronger
& bigger than wimpy FE's. For what its worth, I had a friend with a C80
dump truck with a 427. So he put headers. about a month he put the
cast iron manifolds back on. All that thing did with headers, was burn
spark plug wires just sayin
