Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 10-17-2014, 08:04 PM
F-1 F-1 is offline
F-1 is starting off with a positive reputation.
Unhappy Fuel pump issues with my '48 F1 V8
Please Help!!
Out of the blue my engine stalled while driving..after several attempts to restart the engine I determined that there was no gas getting into to my glass see thru filter going to the carb.
The fuel pump looked pretty old so I decided to replace the fuel pump and filter.
Bingo!! Plenty of fuel getting to carb and truck ran all day until finally another stalled engine and another empty fuel filter.
I'll admit I had to refer to the installation instructions a few times to be sure I was puttying things back correctly. One piece of instruction said to check the push rod for wear and if necessary replace.
Question..how do I know if the push rod is worn..looked ok to me. That rod has different ends..I placed the smooth end into the block (inserted in hole) and the high hat looking end into what look like an upside down cup. Not sure that was right but again, engine ran great for several hours highway and local driving.
My conclusion is that there was nothing wrong with the old pump and filter to begin with and the original cause of the problem has resurfaced..
Ok..but what could it be??
Any thoughts from you good folks please let me know..otherwise $$$ to my local mechanic which I would prefer to avoid.
Old 10-17-2014, 08:08 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to behold
If the pump is putting out good flow at times, look for fuel supply starvation. Is your cap vented, a must? Does fuel flow freely if you disconnect the line at the bottom of the tank where the shut off valve is? Make sure the gasket at the glass fuel bowl is not leaking. These pumps will not suck fuel if they can suck air.
__________________
Ray
1949 F-4 Built to drive--script bed.
1956 F350 Stock rebuilt script bed
2007 F150 SC. Driven once in a whle.
If there’s one thing that the government is highly skilled at, it is creating excessive amounts of bureaucracy and extra layers of red tape for people to wade through.
Old 10-17-2014, 08:09 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.
Is the fuel line clean?
Are all the soft lines sound and not collapsed?
Is the gas tank properly vented?
Old 10-17-2014, 08:37 PM
F-1 F-1 is offline
No leaks that I can see..I removed the fuel line from the pump to the gas tank and it flowed freely. Lines don't look collapsed or soft anywhere and from what I can tell all lines are clear.
Never had this problem before so can I eliminate the possibility that cap is vented properly?
how can I tell if I'm sucking air some place?? connections seem pretty tight and again, if I was sucking air before, I would hope that I eliminated any such problems when I installed new pump and filter. Maybe I should Just replace all the fuel lines and clean out my gas tank..
Old 10-17-2014, 09:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud of
The stock fuel line from the tank to pump is the low point of the system. All the rust, mud and junk collects in it. They can flow fine one minute, nothing the next. There's honestly no good way to clean it out without removing it, the rust particles set up like concrete. Compressed air may get some out. I'd venture to say you may as well replace the line.
There can also be stuff in the tank that covers the outlet pipe, then is released when the truck stalls. Past experience of people on the forum includes: rust flakes, chunks of RTV, lid liners from fuel additive caps, twigs, etc. With a strong flashlight, you can look down in the tank from the filler opening, after pulling the tube.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree MSD, Rochester 2G, Red's Headers
“It’s really hard to make predictions, especially about the future.” -- Yogi Berra
Old 10-17-2014, 09:38 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
Originally Posted by F-1 View Post
Question..how do I know if the push rod is worn..looked ok to me. That rod has different ends..I placed the smooth end into the block (inserted in hole) and the high hat looking end into what look like an upside down cup. ....
I'm 99.9% certain the "high hat" end goes against the cam. It is a hardened material.
You can tell if the pushrod is worn by measuring it. Overall length is 10.0625" (10-1/16") when new, it shouldn't be much shorter than that at all. I doubt that's your problem, but I do think you need to flip it.
__________________
Ross
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Truck still stalling and how to prevent a new gas tank from rusting Thbifeb 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-11-2013 02:37 PM
Intake valves sticking webslinger67 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-14-2013 03:47 PM
78*351m manual fuel pump? JETT 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-20-2007 01:55 PM
intermitant driv'n me crazy fuel starvation? 76 F250 4X4 Fuel Injection, Carburetion & Fuel System 11 10-15-2004 11:48 PM
Wakin' up a 72 F-350 FLGator 1967 - 1972 F-100 & Larger F-Series Trucks 1 08-03-2004 01:43 PM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
