REFUSES TO START after Running ?
Old 10-17-2014, 03:35 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
Exclamation REFUSES TO START after Running ?
I'm looking to buy this 95 PS w/285k. The truck starts and runs just fine, but if you stop and turn the engine OFF it will refuse to start back up.
It needs to sit about (15) minutes and only then will it start back up.
What do I need to be looking at to fix this issue ?
TIA
Old 10-17-2014, 03:57 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Is it warmed up when you shut it off and try to restart?
Old 10-17-2014, 04:11 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
I believe so. I've not yet seen the truck. Getting this info over the phone from the Seller.
They said when out driving, stop at convenience store, they have to sit and wait about (15) mins before it will start back up. It does crank over, but refuses to start.
Old 10-17-2014, 04:19 PM
CampSpringsJohn
A scan tool could point out the problem. It is likely an oil related problem. O-rings are the first thing that comes to mind. When it gets hot, oil is thin, and leaks around the o-rings not allowing it to build oil pressure to operate the injectors.
Old 10-17-2014, 07:40 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Ipr orings.
Old 10-17-2014, 07:44 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
^^Agreed. This is a classic symptom of blown o-rings. Either injector o-rings or IPR o-rings. I'm more inclined to suspect IPR. If that's what it is it should make for a good deal on the truck. It's a $20 fix that may take you a couple hours to do if you've never done it before. Not a hard job, just takes one specific socket and some patience.
Old 10-17-2014, 08:42 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel
OldWoodsDiesel is offline
X3^^^
I had this with my red truck. I never replaced the IPR or injector o-rings, though. I had let the oil go ~4000 miles at that point. Changed it out and all was fine for the rest of that truck's life.
So, maybe this potential purchase just needs an oil change! Hopefully it's a good deal!
Old 10-17-2014, 09:27 PM
fordpride's Avatar
fordpride
fordpride is offline
X4^^^^^^^^
Old 10-17-2014, 10:27 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
Question
Thank you all for your replies.
How difficult/expensive of a repair is this ?
Is there a procedure for it here somewhere ?
Old 10-17-2014, 11:24 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
x5........
Old 10-18-2014, 08:15 AM
fordpride's Avatar
fordpride
Not hard at all and cost around 15 bucks
Old 10-18-2014, 10:47 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
Could someone please point me to the "How-To's" on how to replace this IPR O-Ring and Injector O-rings ?
TIA.
Old 10-18-2014, 11:52 PM
oldbird1965
Old 10-19-2014, 04:46 AM
427 fordman's Avatar
427 fordman
427 fordman is online now
TIA.
Pull the ipr and do the orings on that first. That is probably your problem. Injector orings are a little more work and money.
Old 10-19-2014, 12:26 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
Never mind. The truck was a total POS and should be sold for scrap.
Quick Reply: REFUSES TO START after Running ?
