Transmission issue - 4r100 - v10 excursion
Old 10-19-2014, 07:15 PM
Tom's Avatar
Tom
Tom is online now
Holy CRAP...don't think I've ever seen a filter that bad. Glad it wasn't the transmission!
  #32
Old 10-20-2014, 07:17 AM
Paul Titus's Avatar
Paul Titus
Paul Titus is offline
Originally Posted by ExploringNH
Here was the issue:
I checked it about 3 weeks ago. I've done a LOT of miles down dirt roads since then!
The dirt isn't the issue, how do you guys manage to mangle the air filter or did you do that on removal?
  #33
Old 10-20-2014, 08:06 AM
ExploringNH's Avatar
ExploringNH
ExploringNH is offline
It was so dirty/clogged that it collapsed on itself under the suction from the engine, almost completely blocking airflow and causing the reduced power issue.
  #34
Old 10-20-2014, 09:42 AM
1 Excursion camper's Avatar
1 Excursion camper
1 Excursion camper is offline
Definitely cheaper than a fuel pump!, and easier too!
Good find!
  #35
Old 10-20-2014, 11:11 AM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
wow. interesting that it collapsed that way. Makes sense.
Did a clean filter resolve the issue?
  #36
Old 10-20-2014, 11:22 AM
ExploringNH
Yes. 100%. The reason I was not able to respond sooner was because as soon as I found the issue, I dropped in a new filter, test drove, and then packed up and headed north for the weekend. I have about 500 miles on it since the filter change, a trip up Mt. Washington Auto Road (big ascent), and lots of off-roading. Everything is good!
I'm very happy for a $20 fix and even happier for a quick fix. I have a trip every weekend for the next month. The backup truck isn't nearly as capable or equipped.
  #37
Old 10-20-2014, 11:25 AM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
Awesome. I bet you were relieved it wasn't the transmission.
  #38
Old 10-20-2014, 07:39 PM
bjm206's Avatar
bjm206
bjm206 is offline
I had this happen on a v10 E450 in a heavy rain storm last summer. The E450 uses the same filter as the v10 Ex but with a different (more direct) routing for the intake. Because of this I was hoping the Ex would not be susceptible to this problem...guess not.
  #39
Old 10-20-2014, 08:29 PM
EXv10's Avatar
EXv10
EXv10 is offline
I thought there was a hole in the side of the filter housing to prevent that.
  #40
Old 10-20-2014, 09:41 PM
wpnaes's Avatar
wpnaes
wpnaes is online now
Your MAF and throttle body will need cleaning if you suddenly find yourself getting 6 mpg after the new filter goes in. Go through a puddle to boot? The moisture/dirt/suction will collapse the filter.
  #41
Old 10-21-2014, 08:37 AM
Captn B's Avatar
Captn B
Captn B is offline
If that happened in a short 3 weeks, it may be worth keeping a spare with you on your trips. With how and where you use the vehicle, it might make sense?
branrobi
1999 to 2016 Super Duty
26
01-13-2019 12:44 PM
89LX306
06-03-2011 08:01 PM
SCscrew
2009 - 2014 F150
08-28-2009 03:20 PM
260karl
Modular V10 (6.8l)
15
04-08-2009 12:28 AM
V8EXPLR
2004 - 2008 F150
19
06-12-2008 10:49 AM
Quick Reply: Transmission issue - 4r100 - v10 excursion
