"nuther old panel
#32
According to the brochure that I posted photos of, the 8' tonner bed for '46 has 48 3/8" between the wheel wells. I would imagine that the panel is narrower because the body was a carry over from 1940. They probably didn't sell enough tonner panels to justify changing the body when they widened the axle in '42. I bet you would have plenty of room to modify the wheel wells to get over 48" between them. At least it sounds like a plan to me. Old trucks can add a lot of cool factor to your business .
BTW I went thru your build thread on your '59 F350 Cummins swap, Very nice build!
Mark
Mark
#33
#34
Well I just returned from my daily walk. Supposed to go a bit longer each day. I think I've seen every episode of gas monkey garage and american pickers twice But... I got some info from my axle, vehicle and trailer collection along the way. The trailer with the '47 tonner pickup rear frame and axle has a whopping 52 1/2" between the inner sidewalls of the 7.50 x 17 tires. That means you are right, I could section plenty off those inside wheel wells of the panel. Bring on the plywood! I should have checked out the outside of tire dimension, but I guess you can measure yours. Makes me think a landcruiser axle is too narrow for your tonner panel. Checked my '47 1/2 ton rear and with 700 x 15 bias snow tires, it's 68" on the outside. The toyota axle with ranges of tires @ 66" to 69" looks like I thought it would. Maybe a modern 3/4 ton rear axle would go under your tonner panel. I think the 52 1/2" on my '47 tonner axle should be very close to modern axles. So you need to find a dana 70 for the rear and a dana 60 for the front!
milkstake
04-18-2018 10:31 AM
ALBUQ F-1
01-26-2008 01:58 PM
