1969 F100 rear shock relocation
Old 10-16-2014, 07:54 PM
robmcg's Avatar
robmcg
robmcg is offline
Hi guys, new to the site and new to the U.S., I've just moved here from Australia. I've just bought myself a 69 F100 and need to get the rear end sorted out. Front has a CV in it, the rear has been lowered, new hangers and flipped the axle, all pretty standard.
My problem is the clearance between the coil over shocks (QA1's) and the bottom of the chassis rail. The previous owner has pulled the bottom of the chassis rail down so it no longer hits on the coil overs, my plan is to move the shocks in board a little, and install a new top shock mount, then straighten the chassis rail lip and box it. I've been looking in this forum and others and cannot really see anything like I want to do, Has anyone done something similar to their rear? The axle is out of an Explorer, it's got discs, still the original leaf springs. I'm also interested in notching the rear frame to get a bit more suspension travel.
The shocks are off now, I'm going to pull the tray off on the weekend so access to the area is not a drama, thanks in advance for the replys.
The picture is of the truck stopping at Sacrmento for gas, I drove it home from San Francisco to Illinois, runs nice, needs a bit of suspension work first up, just rebuilt the trans this week.
Old 10-16-2014, 08:09 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Welcome to the State and congrats on your sweet ride. That's downright purty.
In terms of an axle flip and rear shocks, I used Fatman Fabrications' kit and it came with shock relocation brackets... they adapt to the stock axle's shock mounts but perhaps the same principle can be applied to an 8.8. I sketched up some dimensioned drawings and provided pics in my build thread:
Start here: https://www.ford-trucks.com/forums/1...l#post14483556
Old 10-16-2014, 08:36 PM
robmcg's Avatar
robmcg
robmcg is offline
Thanks mate, I'll have a look there, nice thread and build you have there
Old 10-17-2014, 08:33 PM
coupe5oh's Avatar
coupe5oh
coupe5oh is offline
I just cut/bent/re-welded the upper mount on mine to make the shock parallel with the frame. Then used some prefab lower mounts.
Old 10-17-2014, 09:12 PM
robmcg's Avatar
robmcg
robmcg is offline
That looks nice and clean, do you have some better pics of the upper mount you made, also where did you get the lower mount, seems to be a lot around but I'm not sure on the be done to get. Any chance of a closer look at the c section you did, looks very tidy. Are you using standard leaf springs on it?
Thanks again for posting.
Old 10-17-2014, 09:26 PM
HIO Silver's Avatar
HIO Silver
A & A Manufacturing - Shock Mounts
Ballistic Fabrication: Brackets and Tabs
Make your own axle flip brackets;
Originally Posted by HIO Silver
Here are my shop copy drawings for the leaf spring saddles and the shock adapter brackets. Fab your own C-notches using 4-inch DOM tubing and 3/16ths plate steel to box your frame....
65-69 Ford 100s use Monroe #34817 shocks (loop mounts on both ends). They are OEM spec'ed as front shocks for 63-87 Chevy PUs.
70-79 F100s use Monroe #34899 shock (stud top mount & loop at the bottom). They are OEM front shocks for 75-91 E100 Econolines).
Saddles... The taller saddle (4-inch side) is installed to the rear:
Old 10-17-2014, 09:51 PM
coupe5oh's Avatar
coupe5oh
coupe5oh is offline
I don't have a very good pic, sorry. The upper is a stock mount. I just pie cut a little section out so they would fold in. Then welded them back together if that makes sense. The lowers I bought off eBay...
My c notch is just 1/2 a piece of sch 40 4" steel pipe. I'll give u a link to my build. There should be pics of it in first couple pages. http://fordification.com/forum/viewtopic.php?f=22&t=66753
Old 12-08-2014, 12:40 PM
robmcg's Avatar
robmcg
robmcg is offline
Does anyone know where you can buy new rear spring hangers for a 69 F100 2WD? I've been looking all through the web, ebay etc, but cannot find anything. They have them for the 73 & up models, but not the 67-72. Main difference is the leaf spring width, on the 73 & up they go to 2.5" wide springs, while the 72 & down are still 2.25" wide.
Old 12-09-2014, 02:34 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Front of the rear spring or rear of the rear spring? With or without flex-o-matic rear suspension?
Old 12-09-2014, 02:51 PM
robmcg's Avatar
robmcg
robmcg is offline
Rear of the rear springs without flexomatic.
Old 12-10-2014, 02:55 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
The Ford part number was C8TZ5775E. But nobody shows them on my parts locators. Guess you'll have to go JY hunting.
Ford used this number to replace the 1964 F100 4X2 ones but I wouldn't use 'em. Try finding:
65/72 F100 4X2 with or without flex-o-matic. The rear hangers are the same.
66/72 F100 4X4.
Old 04-21-2016, 04:17 AM
72RichB's Avatar
72RichB
72RichB is offline
Sweet truck robmcg, love the colour, have been looking at Orange for my F250.
The following users liked this post:
Martin Torres
20
08-29-2017 11:30 PM
fearmore
04-01-2015 03:49 PM
OregonJen
1947 and Older Ford Trucks
02-11-2012 12:19 PM
cseastaugh
04-04-2005 12:44 PM
Quick Reply: 1969 F100 rear shock relocation
