v10 dyno numbers
Banks use to have long tube headers, long tubes are the only type that will show gains, shorty headers are completely pointless. I have a set on my 5.4 and they did nothing but lighten my wallet! I do now that 4.6 and 5.4 show improvement only when a set of long tube headers are installed (mustang and lightning dyno charts)
Why the need for power? are you towing or do you have larger than stock tires? If so tell us what OEM gears you have, GEARS are the only real improvement that you feel and see on the 5.4 and V10 motors in Super Duties
The following users liked this post:
I replaced my cracked stock manifolds with stainless Gibson headers, see link below. Mileage on my 05 F250 5.4 was between 12 and 12.8 MPG[1]. After the swap I did hit 13.8 MPG once, but every other fill up has calculated 12 to 12.8 MPG[2], just like stock.
I have no dyno graphs to quantify any changes in power delivery. Butt dyno says there isn't much power difference. There was a bit of an increase in exhaust note though, nothing rude, just a bit more volume at 3k RPM and below (where I spend most of my commute). Above 4k RPM it is considerably louder than stock.
5.4L Gibson SS Header
6.8L Gibson SS Header
[1]milage on OE plugs that had 122k miles, OE manifolds, and OE battery
[2]calculated with new Autolite plugs, SS headers, and a new Optima battery
if you want more power you need to up the compression and do some cam work. 6.8's have lower compression ratio than 5.4's and theres probally a good reason for it. So while you have the heads off to replace the pistons to higher compression ones, re-cam, and change the valve spring strenth, do better on the gaskets becuase that probally part of the reason why the 6.8 has a lower compression ratio than the 5.4
so yes, after you do some engine internal work, will intake work and exhaust work pay off, probally, but not likely if thats all you are going to do.
before you take the motor down, measure your oil PSI and decide if you need to do something to the oil pressure while you have the pan off.
i have 35s and 3:73s its just like pulling hills here in pa 4th is screaming but as soon i i shift in OD its falls on its face i was looking into headman headers because the factory exhaust well ill just say my garden tractor has a bigger exhaust than it haha i run 93 octane most of time and keep the rpms under 3k because i feel there not capable of it but i know there good for some revs like 5200 i was reading on the one rv forum
Before sinking money into the cat back check into the SPD y pipe and 5 star tuning.
I currently have the y pipe and MBRP cat back. It does sound awesome however not sure if horsepower or mileage improvements. My best was 13.5 with a full bed of camping gear, family of four and a seadoo in tow.
If your search for some of WE3Zs posts he has done the Banks headers, 5 star tuning and 4.88 gears with his 35s and has shown improvements towing his 41' camper. His is pretty much a dedicated tow rig though.
with a 9.2:1 compression engine, you will get no power diff between 87, 89, or 93 octane. you need to get to 10.5:1 compression ratio to benifet from 93 octane.
93 octane in a 9.2:1 engine is going to cause a lot of carbon deposits.
I'd show you some third party sources that confirm what we've told you, but you'd ignore them. After all, they're on the internet.
