Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 10-16-2014, 05:46 PM
ij72 ij72 is offline
ij72 is starting off with a positive reputation.
no guts when towing
I have a 97 7.3 powerstroke automatic 2wd f250. Recently towed my 7,000 lb camper. This truck was weak. It shouldn't be that way. Powerstroke should haul that campers *** down the road with no problem. By the way, this only has 153,000 miles on it. Any suggestions as to what is going on with it?
Old 10-16-2014, 06:00 PM
lemonshindig lemonshindig is offline
lemonshindig is starting off with a positive reputation.
There's not a whole lot of information here for us to work with... It could be normal, or it could be a number of things. 7,000lbs is probably heavier than you think.
If you have an android, buy a bluetooth dongle, buy the "Torque Pro" app, set it up to read ICP, IPR duty cycle, and Boost pressure. Then get back to us.
__________________
'88 F-250 6.9 IDI ZF-5 4x4 Standard Cab ?? Miles
'94 F-250 7.3 PSD ZF-5 4x4 Standard Cab 374k Miles
'67 Mustang 289 C4 "Who Cares?" Miles
Old 10-16-2014, 07:26 PM
DougJ_1997PSD's Avatar
DougJ_1997PSD DougJ_1997PSD is offline
DougJ_1997PSD is starting off with a positive reputation.
according to the manual, that truck is rated for 14k. it wont be fast but it'll do it. did it slow down alot on hills or did it just feel sluggish? and can you compare it to another time you towed 7k+?
__________________
1997 F-250 ECLB Powerstroke 124,000 miles,
6 position chip, K&N cold air intake, rebuilt E4OD trans,
Meyers Plow, 4" muffler and cat bypass,
4.10 10.25" rear end, 4x4
Old 10-16-2014, 07:47 PM
Don Naslund Don Naslund is offline
Don Naslund is starting off with a positive reputation.
You didn't mention if the transmission is shifting down. Try shifting down manually and go through the gears. If it is stuck in overdrive, it will seen gutless.
Old 10-16-2014, 07:55 PM
Yes it slowed down on hills
It shifts down, then immediately goes right back into overdrive
Old 10-16-2014, 07:59 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Take it out of OverDrive
__________________
Looking for Blue 40-20-40 seats. PM me !!!
Old 10-16-2014, 08:25 PM
fordpride's Avatar
fordpride fordpride is offline
Louisiana Chapter LDR
fordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud of
That 7k turn into 8-10 depending on how much it loaded
__________________
Mike
Click here to join the Louisiana chapter
2014 RAM 3500 cummins
96 F350 CC ZF5 53k with grandpas package
Louisiana FTE Member Map
Old 10-16-2014, 08:45 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE is starting off with a positive reputation.
Is it a fifth wheel or bumper pull. The taller fifth wheels have to push a lot of wind
__________________
It's hard to soar like an eagle when your flying with a bunch of turkey's
1997 F-350 xlt cclb PSD 4x4 zf5
1989 F-350 4x4 7.3 c6 auto retired
2000 F-150 XLT 4x4 4.6 e4od
Nick
Old 10-17-2014, 12:38 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to all
You got that right Mike. My 12K 5er weighted in at 16K with all our junk in there!
That's right Nick, like pulling a parachute thru the air!
__________________
Glenn
The Mule-96 2WD F250 EC/LB auto, Lots of Mods!! Semi retired, still runs great after years of pulling!!
The Mare 97 dually cc, s366 turbo, stage II's, IC, studs, springs, rods, JW auto, 4:10 LS, efuel, FS2500 bypass oil filter, HVHF IDM, IH WP, 6.0 trans cooler & rad fan, MBRP 4", SD tensioner, AFE, 220 amp alt, 38G tank, soundproofed, 3 different TS chips
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
2013 F250 6.7 Fuel mileage and other problems Bsharp76 6.7L Power Stroke Diesel 15 10-22-2013 06:04 PM
Which transmission cooler to use. jlewis2962 1987 - 1996 F150 & Larger F-Series Trucks 3 09-28-2012 08:13 AM
Lacking Power! Herzog 1994.5 - 1997 7.3L Power Stroke Diesel 68 08-13-2012 08:20 PM
99 F250 ??? derbinator Super Duty & Heavy Duty 2 05-04-2008 12:06 PM
nice to be here pwrstrktrnsprt New Member Introductions 1 11-03-2005 04:37 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
