Front end replacment/sugestions
We'll with everything else I've been doing to the truck I guess I should replace my lose front end. Steering wheel has a lot more shake in it now when I go over bumps. So I am going to replace the box with a red head and already have a rancho stabalizer. What else and what brands do you all like for anything else to replace. As in u joints and ends.
I just did this at 173K. Mine was getting bad. All oem ball joints, track bar, track bar ball joint, all tie rods bearings and hub seals. I could have gotten away without doing a couple items but since you have to tear down the hub seal and spindle to do the ball joints I just did everything except the box. I went with oem because it wasn't much more and on some parts less than the parts stores. Ford also now has a two year unlimited mileage warranty. But I figured the truck made it to 173K with the stock parts odds of me doubling that are slim so I have the confidence of knowing(or thinking) it should last awhile.
I just put a red head gear box and stabilizer on mine. Previous owner had replaced the ball joints about 70K miles ago and they were tight. Have not done drag links or track bar. I still have some play and I'm a little disappointed. Perhaps the links and track bar are my problem, but I haven't checked on it since I added the stabilizer and red head. For me, I'm not sure the stabilizer didn't help more than the new gear box.
Trac bar
I did not replace the bar just the ends. There is a bushing on one end and a ball joint on the other. I got the bushing end from NAPA. The ball joint I could only find a Motorcraft part number and I got it through Amazon.
