Locking Nuts, Nylock and Torflex
Old 10-16-2014, 11:44 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
I have used nylock nuts on many projects over the years and have often wondered how many times they can be used and reused. From what I can gather, the prevailing wisdom is that you can reuse them as many times as you want until such time as they lose their ability to hold their torque. I have never gotten too technical with the measure of torque on these nuts, does anybody have anything to add to the topic?
While at the fastener store I did look at some other nuts that were called torflex nuts. I have seen them used as OEM fasteners on exhaust systems but I didn't know that they were readily available in various sizes. Anyone use these nuts? Good, bad, indifferent?
Old 10-16-2014, 12:06 PM
imlowr2's Avatar
imlowr2
imlowr2 is offline
Never heard of Torflex nuts? I did a search on google and it didn't come either. Personally, I use the nylock nuts. As far as reusing them? I don't. I guess you can reuse them but why? They are cheap enough to where I just replace them with a new nut and not have to worry about it. There is a guy at the Long Beach Auto Swap meet that sell them by the pound.
Old 10-16-2014, 12:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Do you mean Flex-Lock nuts? Torflex is a trailer axle. http://www.spstech.com/web/user_cont...cat_sp1040.pdf
I had a class in college that included quite a section on fasteners, it's a fascinating subject IMO. Nothing simple about them. The performance of Nylocks or other vibration-resistant systems depends completely on the application. Nylocks are fine for most body fastening, not so much for drivetrain. As long as the nylon is biting into the threads, they will work as intended.
Split-washers turn out to be almost useless for "locking" anything with substantial vibration or load variation. Fine thread fasteners with a drop of LocTite is about as good as it gets.
Old 10-16-2014, 12:31 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is online now
Another good option for high vibration usage are the crimped style of lock nuts. Lawson and Fastenal are two good sources.
Old 10-16-2014, 04:38 PM
ChuckRob's Avatar
ChuckRob
ChuckRob is offline
I am a firm believer in Nylok's, it's the only nut that you will find in my hardware cabinet.
Never had one come loose either bouncing down the highway or race track.
Old 10-16-2014, 06:25 PM
carnut122's Avatar
carnut122
carnut122 is offline
I think of NyLocks as being for light duty applications and not something I'd put on grade 8 or grade 5 applications. Maybe I'm totally wrong? So, please educate me. I reuse them all of the time.
Old 10-16-2014, 06:54 PM
AXracer's Avatar
AXracer
AXracer is offline
I've always been advised not to reuse nylocks more than twice. Nylocks are available in grade 5 and 8. You should use the same grade nuts on the same grade bolts.
Old 10-16-2014, 07:14 PM
carnut122's Avatar
carnut122
Works for me. Thanks! Maybe my experiences just aren't heavy duty enough?
Old 10-16-2014, 07:23 PM
eman92082's Avatar
eman92082
eman92082 is offline
In my Engineering years I came across this product demo video and found it interesting. It's well beyond the scope of Charlie's inquiry but it covers all of the fastener locking strategies. (Nylok included) If you have 8 minutes to spare, this may surprise you.
For me, I'll use nyloks twice but don't use them under the hood with high temps.
Old 10-16-2014, 07:41 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Very interesting Eman! Thanks for sharing
Old 10-16-2014, 07:52 PM
truckeemtnfords
Interesting video, the only thing I don't agree with is the double nut test. To properly double nut the lower nut must be held after torquing and the up the upper nut torqued against the stationary lower. Just putting another nut on top does nothing except raise cost per fastener. IMHO
Old 10-17-2014, 10:31 AM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
I work for Atlas Copco Secoroc, we produces rock drilling tools. My collegues that design the drill rigs uses the above nord-lock washers on all places that is subjected to heavy vibrations. Pretty much the whole drill rig. For quality, they are not reused but can be. They are really great att keeping the bolts tightened.
Old 10-17-2014, 12:02 PM
eman92082's Avatar
eman92082
Looks like I unintentionally Sorry Chuck.
Old 10-17-2014, 01:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's an interesting video, obviously they have a dog in the fight so to speak. But notice the bolt/stud is coarse thread; you wouldn't spec a coarse thread anywhere vibration was a concern. If you look inside about any engine, where there is vibration or cyclic loads you'll find fine threads, usually without any locking means at all.
Old 10-17-2014, 02:35 PM
CharlieLed's Avatar
CharlieLed
Not a problem Ernie, I started this discussion for the purpose of finding out more about fasteners and others experiences. As for the video, it's a good one...I have watched it many times down at Ababa Bolt while waiting on the counter guy. I am going to go back to Ababa and recheck that packaging on the "torflex" nuts, I may have gotten it wrong.
I got off on this topic because I am in the process of reassembling my TCI chassis for my 40 Ford coupe. This chassis has all the bells and whistles including chrome hardware and polished stainless a-arms, etc. I am replacing the steel nylocks with stainless, more for looks than function, but some of the nylocks are chrome plated and I see no need to replace them if they still have plenty of "bite" when they are tightened down.
Quick Reply: Locking Nuts, Nylock and Torflex
