67 Hood lock?
on
Yea the bronco & some vans share the same latch. I did have one with the key pull lock type cable.
Since, I have my hood with a alarm & cable padlock down. I had just put it up on ebay and got $50 bucks for it a few yrs ago.
I came across one last week at the junk yard and do see them ever so often but with out the key for them.
Orich
Orich
D8TZ16700A:
NOS Parts.....913-220-5746.
McDonald Obsolete.....812-359-4965.
on
Since I am working 6/12 hr. nights, and trying to sleep days, I will try to call for a price on all this stuff tomorrow... but it being Sat... I may wait until Mon...
John has sound advice here... and some further contemplation is in order.. I do like the idea of the locking cable latch system... seems pretty fool proof to me... but so is my pad lock idea, and it is way simple.. drill 1 hole, put in the lock, done deal.. mmmmm..... simple vs upgrade.. ??
D8TZ16700A included:
D8TZ16700B...latch replaced by E7UZ-16700-A
D3AZ16907A...clip.
D8TZ16B968A..plate.
D5DZ16914A....cable.
D8TZ16978A....key and lock.
1-55926s6M...screw..1/4"-20 X 1/2".
2-40927s2......screw..1/4"-20 X 1/2" also.
1-386132s.......cable retainer clip.
1-instruction sheet.
D3AZ16907A...clip.
D8TZ16B968A..plate.
E7UZ-16700-A (replaced D8TZ-16700-B) .. Locking Hood Latch (only): 1973/79 F100/350 - 1975/91 Econoline - 1978/79 Bronco.
D5DZ-16914-A .. Hood Lock Cable: 1973/79 F100/350 - 1975/76 Granada/Monarch - 1978/79 Bronco.
AFAIK, this D8TZ-16700-A .. Locking Hood Latch Kit will not fit 1967/72 F100/350's.
El Jeffe: Does the hood latch on your 1968 have a safety catch? 1967/68 factory installed hood latch (C7TZ-16700-A) is different than 1969/72.
Parts catalog shows C9TZ-16700-A for 1967/72, but C9TZ was the service part replacement for the C7TZ-16700-A latch.
In 1982, I bought a bicycle locking cable and padlock for my '65 F100, passed it thru an existing hole in the hood. Had just installed an R-27-FA 80 amp battery, didn't want to lose it.
The cable was long enough that the hood could be raised 8" so the padlock could be accessed.
The latch ONLY was D8TZ-16700-B .. Ford replaced it in 1987 with E7UZ-16700-A
AFAIK, this kit will not work on 1967/72's. In the late 1970's, sold one to a friend w/a 1971, he returned it, said it wouldn't work.
Read the last 2 lines in post 21 which I edited in after the fact.
on
Thanks again ND.. you come through again, and as usual, with good, and accurate advice... I am now thinking that it would be a fairly major project to change the '67 hood latch, over to the cable pull, locking hood latch. As you suggest, it will not fit. At least, not a direct fit, and probably way more trouble than its worth.. I will go back to the drawing board, and use my wide (2.25") Master #101 pad lock, and call it good for now.
Would have been nice though, and way trick..
Baja
Baja
on
The 73& up latch mounts just about the grille where as 67-72 mount in the hood as you know. I've looked at doing this 75 pull cable latch before. And maybe with the engine out so, I had working room for that area to make a bracket for the latch bar and do the adjustments. Or with upper grille top sheet metal plate that bolts across the for better access for adjustment. Well my simple cable & padlock won out.
Like I'd said before my hood latch is rigged with trick switch to my alarm system.
So Just a I/2" of the lever movement sets it off with out releasing the hood latch itself.
So, I feel it's fairly save parking on the public street in my neighborhood.
Here in San Jose ca. some guys cut a hole in the hood above the battery and cut the
power cable to the alarm right in the home owner drive way that had a moving sensor light setup. They stole the complete dvd video system from the big caddy a few yrs ago..
If the Thief's want some thing back enough they will get it one way or another.
Orich
Orich
#29
On the cable latch gig we got goin' on here, The latch is on the hood of a Bump but on the core support of a Dent. So I wonder if the Dent hood latch catch (16900 in Bill's pic) would bolt to a Bump hood?
