fuel additive
fuel additive
have an '08 F 150 4X4 5.4L with only 40K on the odom, just had the engine oil(Royal Purple 5W-20) analyzed and was told to use a quality fuel additive because of slight fuel dilution.....oil was in for 6 months and only 1850 miles as I was considering going a full year with the synthetic with the low miles but was concerned about the dilution which I found out about on a previous UOA.
any suggestions on a fuel additive for these engines?
thanks
thanks
thanks
thanks
I like Techron but fail to see how that would affect fuel dilution of the oil. I would recommend changing oil far more often, and given your use, I don't think you need purple food coloring in your oil, or even synthetic oil. Motorcraft syn blend is just fine. And do try to drive the engine for a longer trip at least once weekly to cook off fuel and water.
If you can use top tier fuels, your need for a fuel additive should be minimal but I still run Techron thru all our vehicles about twice a year. Costco sells 6 packs of Techron really cheap compared to parts stores selling single bottles. (You can google top tier fuels for brands.)
George
George
Your truck is fairly young for this problem. I concur with everything George mentioned above. Barring something like a leaky injector, which would cause dilution, I personally would switch to a good diesel oil for a few oil changes to take advantage of the increased level of detergents. In case your rings are sticking, this may help. Others have used stuff like Marvel Mystery Oil or ATF with varying results but I'm not big on additives (except Techron).
Indiana-red4x4
2004 - 2008 F150
02-02-2006 05:04 PM
