violent shaking after lift kit install
Old 10-15-2014, 11:47 AM
Jarryd's Avatar
Jarryd
Jarryd is offline
I don't have an alignment yet so I know it's not going to ride perfect but after hitting a bump, the truck started shaking side to side hard until I slowed down. I'm not sure what would cause this, everything looks tight, I can't figure it out.
Old 10-15-2014, 11:52 AM
SteelHorse4x4's Avatar
SteelHorse4x4
SteelHorse4x4 is offline
Alignment, worn pivot bushings, could be many things. Camber is probably off quite a bit among other things. Same tires?
Old 10-15-2014, 11:54 AM
Jarryd's Avatar
Jarryd
Jarryd is offline
Same tires. it was fine for 2 days, then it did this twice in less than a mile on my lunch break. I feel like whatever it is will get worse.
Old 10-15-2014, 11:58 AM
SteelHorse4x4
Park it and start shaking as hard as you can to see if anything shows up unless you have a jack handy.
Old 10-15-2014, 12:01 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
That was my plan of attack. I'm frustrated because I have to get out back to work because it's raining and I can't miss anymore.
Old 10-15-2014, 12:07 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
Shaking out doesn't yield anything out of the ordinary from what I can tell. I may have a radius arm that needs more tightening but I don't see anything out of the ordinary.
Oddly enough, I feel like it looks a little taller now too. Hopefully it was just a fluke.
Old 10-15-2014, 12:35 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
Could it be due to play in the tie rods? My camber changes dramatically based on whether I'm going forward or backward.
My ball joints were replaced about 1000 miles ago so that should be out of the question.
Old 10-15-2014, 12:46 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
There seems to be excess play in the steering wheel too which is why I wondered about that being a possibility.
Old 10-15-2014, 12:52 PM
SteelHorse4x4
New pitman arm? properly torqued? Absolutely tie rods could be the problem, but you're there, I'm not. LOL Yes camber changes on these trucks fwd/rev.
Old 10-15-2014, 12:56 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
I know it changes, but not this much. I feel like the excessive play could be allowing everything. I just need to take it for an alignment and have them adjust everything properly.
Now to figure out the best place to do it.
I have a hard time trusting anyone in town.
Old 10-15-2014, 01:35 PM
clarkbre's Avatar
clarkbre
clarkbre is offline
I would recommend getting a second person to help you.
With the tires on the ground, start the truck, have your helper move the steering wheel while you look at each steering component as it move under load. It may be something that simply needs tightening or you may find that the steering box itself has some play in it or where it mounts to the frame.
Old 10-15-2014, 02:16 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
F250 with a lift? F350 with a lift? Whose lift kit? Springs only?
Sounds like you have the "death wobble". I'm chasing a the same thing, just mine isn't violent yet.
Old 10-15-2014, 02:18 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
F150 rwd rough country lift.
Old 10-15-2014, 04:52 PM
Ddaybc's Avatar
Ddaybc
Ddaybc is offline
My '52 Ford Panel Truck had the "death wobble" too. Shook so hard before I could pull over that it shook the glasses right off my face! It turned out to be a combination of loose wheel bearings and worn out tie rods.
Clarkebre has the right idea. Following his process may give you some clues as to where to start looking.
Old 10-15-2014, 04:58 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
I'm almost positive it's the tie rods after driving but I don't know what I'm doing when adjusting. There's tons of play in the wheel which suggests they're loose because if I keep tension on it, no wobble.
Quick Reply: violent shaking after lift kit install
