pros/cons of a 351m
Husker, I found an "Offenhauser" aluminum intake at a swap meet and mounted a rebuilt "Demon" 4-barrel on it. I've only had it running once for a very short time. I'm in process doing a lot of body work right now. I need to re-wire the whole system as well, so I've got lots of work yet to do...
I have one in my 1980 4x4. I got it from a friend of mine who got it from the previous owner when it stopped running. They had just put new bushing in it, new plugs, wires, cap, etc. Couldn't get it to run again. I found out a part sheared in the oil pump, locked it up, then it broke the distributor gear in half. New oil pump, new non retarded timing, timing chain and it was good to go.
It has 30" tires on it and 3.50 gears, spins them over fine in 4x4 at a dead stop. I got a 4v intake for it but haven't gotten the 500 CFM EDL manual choke carb I want for it yet. Later on I want to drop a small cam into it and a set of headers. It still has the stock exhaust on it for now.
For a everyday v-8 I am happy with it, it is just a bump around truck.
Beanscoot
12-26-2007 10:12 PM
calazo
32
07-13-2004 06:59 PM
