1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
low voltage at inertia switch- f250 V10 no start
Old 12-06-2014, 10:41 AM
mcmahon_66's Avatar
mcmahon_66
mcmahon_66 is offline
I have a 2001 F250 V10. The truck will not start, no fuel. I started checking the power going to pump and I am finding I am only getting 6.9 volts to the dark green/yellow wire. I bench tested the relays under the hood and all have continuity. I am not sure if there are any other relays that can be checked. I am hoping someone can help me out.
Thanks
Mike
Old 12-06-2014, 12:22 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
You do know, don't you, that the pump is only powered for around 2 seconds only when the key if first turned from OFF to RUN, until the engines starts?
Any reading made outside that window is irrelevant and prone to cause confusion.
Old 12-06-2014, 12:39 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
And its been my experience that 9 times out of 10 a no start on our trucks ends up being the fuel pump..
Old 12-06-2014, 03:35 PM
mcmahon_66's Avatar
mcmahon_66
project Thank you, I didn't know that about the pump. I was trying to advoid dropping the tank, But I guess i will have to.
Thank you both for your comments
Old 12-06-2014, 03:46 PM
Ltngdrvr's Avatar
Ltngdrvr
Ltngdrvr is online now
Received 3,322 Likes on 1,756 Posts
Don't know if ford gas trucks are like ford cars, but my '04 crown vic has a fuel pump module that controls the power output to the inertia switch, if that is bad then you don't get full voltage.
Old 12-06-2014, 04:03 PM
projectSHO89
An 01 Super Duty does not have the FPDM.
A fuel pump replacement may well be in your future, but your initial diagnostic method is invalid and would likely result in wasted time and effort. Doing the diagnostic PROPERLY will get you to your correct diagnosis quickly. If you have your battery power at the output of the inertia switch during the pump priming cycle, then you've eliminated everything except for the rear wiring harness and ground and the fuel pump.
Old 12-14-2014, 09:19 PM
90turbo1's Avatar
90turbo1
90turbo1 is offline
I think you are on the right track. I just went through this on Thursday with my v10 superduty. drove home from work, it started running like a 4 cyl and then I shut it off and would not start again. I checked the fuse under the hood, good. and found the relay was working, I had good voltage to the inertia switch.
you should have battery voltage at the inertia switch when the relay is activated. Anything less than battery voltage usually indicates a problem with the relay or battery voltage in general. did you crank the car a lot trying to start it?
anyway, my relay for the fuel pump is up under the dash behind the radio area. its a pos to get to but you need to check it.
the system is simple (mine is a 2001) the ecm grounds the relay and also monitors the voltage output from the relay. the relay takes battery voltage and sends it to the inertia switch when activated, through the inertia swich and on to the pump. Mine ended up being a faulty pump. It was not that bad to change the pump but a final test is to crawl under the truck and find the B+ power wire to the pump itself and have some one turn on the key while you are testing voltage there. you should see battery voltage for a 2 sec period when the key is turned on. if you have no voltage or low voltage to pump you have other issues. if voltage is good, you need a pump.
BTW.... I pulled the bed off for the pump replacement, it is much easier providing the 6 bolts come out of the bed easily.
Old 12-25-2014, 09:55 AM
mcmahon_66's Avatar
mcmahon_66
Thank You everyone, I finally had a chance to drop the tank and replaced the fuel pump. The truck runs beautiful again.
Thanks
Mike
archeryelk28
02-10-2015 08:31 AM
901fan
09-28-2012 09:51 AM
sxmtx
03-22-2012 01:11 PM
kjeremiah
03-24-2011 09:09 PM
V10_Cougar
Modular V10 (6.8l)
11-29-2009 04:48 PM
Quick Reply: low voltage at inertia switch- f250 V10 no start
