52 Ford F1 Hood reattachment
on
Don't know that it makes a difference. I recently re-attached mine and did inner first and then outer. That's the easy part anyway. Getting it to close properly was a real PITA! I could not tell you how many times I loosened and moved those inter hinges around until I got it right...
Thanks for all the advice guys! I got my hood bolted on finally. I attached the outer hinges on, bolted the top arm of the outer hinge to the hood, then pushed the hood up and in line with the lower arm of the outer hinge. Then I connected the inner hinges next. Now I'm off the bolt the inner fenders and outer fenders on.
Thank you!
Jon Preston
Thank you!
Jon Preston
Make sure that your body mounts are solid first otherwise you will chase your tail (more than normal) trying to make the hood fit right. See this post with pix:
https://www.ford-trucks.com/forums/1336613-on-a-50-f1-is-there-any-side-to-side-adjustment-on-the-radiator-saddle.html#post14695806
frank_65
04-29-2008 11:13 AM
