Upgrades to Wastegated Banks Turbo?
OK, guys, I'm curious: Are there any wheel/housing upgrades I can put on my Wastegated Banks turbo(TE06H) to increase boost throughout the range? My rebuilt engine has headstuds and will have a lower CR(~18.5), so I should be able to handle like ~20PSI of boost.
The stock turbo won't get me there -- 15 max, at higher RPMs. I'm looking for some way to upgrade it so I can increase my boost throughout the range -- for example, I can only get about 5PSI at 1600RPM max, increasing to 10-15 in the 2200-2500range. I'd like to somehow get 10PSI at 1600RPM, and hit >20PSI up in the range(I figure I'll use the wastegate to keep it at that 20PSI at that point.
Any thoughts/options?
If you really want an increase, i would personally be looking at an altogether different turbo. I wasnt impressed by the HX35, but alot of guys like them. I would look at something like the S256, or S258 or even S360 depending on how much fuel you are looking at.
S256 and an intercooler would be a very responsive and efficient setup for a 90cc pump. Then again, the banks will do 20psi well enough that the IC could easily make up the slight loss in efficiency. If you are looking at a 110 or bigger i would consider another charger.
on
i would personally be looking for a whole different engine lol.if you want "power" leave the old idi behind.they'll do anything "needed" with the banks.if not,she probably needs a tune up or you need a more modern truck with not just more engine,but more overall weight rating all the way around to go with it.
only problem is those pesky payments.
blackpatch
12-25-2009 09:00 PM
