Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 10-14-2014, 04:57 PM
unclegus unclegus is offline
unclegus is starting off with a positive reputation.
1984 460 fuel problems
I have a 1984 Ford Class C motorhome 460 it has been in storage for about 3 years ran when put away but will not start now will start if I pour gas in carb but dies right away i think there is no power to the fuel pumps when i install a jumper wire on the oil preesure sending unit the fuel pump relay clicks under the hood on the drivers side does this indicate that all is ok or is the fuel pump relay or the oile pressure sending unit bad? any help would be appreciated
Old Yesterday, 07:12 PM
Trackerrrr's Avatar
Trackerrrr Trackerrrr is offline
Trackerrrr is gaining momentum as a positive member of FTE.
christopherdwilson1969 Trackerrrr Trackerrrr
Do you have the starter solenoid with two small terminals? One will be marked 'I' and one marked 'S'. If so, try pulling the wire off the 'I' terminal and touch it to the side of the solenoid hooked to the positive side of the battery. You should hear one of the fuel pumps run. If not the pump could be gummed up, the wiring has a break, or possibly a ground problem. You said the RV will fire if gas is poured in carb so that eliminates the ignition. Try filling the carb bowls through the small vent tubes on top, they are about the size of a drinking straw and protrude above the venturi a bit. Then see if the RV will stay running, this will give the pump(s) a chance to start filling the carb.
This is assuming you have an electric pump(s) and the Hot Fuel Handling option.
This also assumes you have gas in the tank(s).
__________________
Chris
1983 F350 Dually Crewcab (Frankentruck), 460, C6, Dana 70
My build/repair thread: http://www.ford-trucks.com/forums/13...rd-pickup.html
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
1984 F250 fuel pump problems????? deputydog03 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 53 11-05-2013 03:41 PM
Surging Carb. mercurycat 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 05-10-2009 08:46 PM
Wierd Idle issue 90 F350 gearhead351 1987 - 1996 F150 & Larger F-Series Trucks 0 03-17-2009 01:45 PM
1987 f250 fuel delivery problem; no fuel delivered SBANANA1 1987 - 1996 F150 & Larger F-Series Trucks 4 03-12-2009 08:08 AM
Please Help, I can't figure out my fuel system problem.... b33cpe 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 02-11-2007 11:17 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
