49' fan shroud
You may want to consider something before it's a problem. If the fan hits the shroud, it will tear up both the fan and the shroud. Best to make sure your clearances are good before you have to go searching for more new parts. And just because your mounts are new, don't necessarily believe they're correct. Aftermarket parts have been known to be less than accurate at times. Even for new cars. Check and recheck everything. My 2c.
I'm not sure what engine that you have (suggest that you add that along with the model to your signature in UserCP along with your location) but assuming that it is a V8 the system really is pretty simple. An ⅛" isn't enough clearance.
Hope this helps,
- The radiator support pad isn't very thick and as long as your support is sitting firmly against it sandwiching it to the front crossmember then that part of it should be correct.
- Next the motor mounts should have 6 pieces on top of the frame (#8, 9, 7, 6, 2 & 3 in the picture). The height if the engine is controlled by how much you tighten the nut (#8).
- Finally the transmission crossmember and the mount there will have an even bigger impact due to their lever arm distance. If your crossmember has been bent up as it would if it hit something then that would move the front of the engine down. Check the bolts on the bottom of the crossmember (if you have an F2-F5) and see if they have been damaged which would give you a clue).
Hope this helps,
Bankrupter
28
11-09-2013 06:35 PM
1978fordf250
08-27-2004 06:59 AM
Big Hands
18
04-30-2003 02:27 PM
