Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Sign in using an external account
Register Forgot Password?
Old 10-14-2014, 12:01 PM
Bud Mud Bud Mud is offline
Bud Mud is starting off with a positive reputation.
351c 4v heads?
these any good to put on a 400 going in a truck? THANKS
http://lansing.craigslist.org/pts/4708722931.html
__________________
Bud
77 highwater 351m c6. currently wrecked thanks to ice on roads and a 16yr old boy.
lower mich
Old 10-14-2014, 12:40 PM
txacoach's Avatar
txacoach txacoach is offline
txacoach is starting off with a positive reputation.
It all depends on what your set up is and what you are building. Here is a link with some information on it.
M-Block 351M/400 Parts Reference
Old 10-14-2014, 02:11 PM
i have all that info, i know these have a large intake port and that can hurt low end trq. I just dont know enough about these heads to make a call, i know the 351m/400 heads dont flow that well on the exhaust side with out a lot of porting. THANKS though.
__________________
Bud
lower mich
Old 10-14-2014, 11:49 PM
SDDL-UP SDDL-UP is offline
SDDL-UP is starting off with a positive reputation.
Bud Mud,
There are two things when doing a 400 4V...
Intake manifold - you will need to run a 351C 4V manifold and spacer plates to make up for the taller deck of the 400
Exhaust manifolds or headers - no such animal for 4V heads in a truck so you are going to have to fabricate something
It all depends on what kind of performance you are looking for. You can get 325 to 375 without too much trouble out of a "normal" 400 performance rebuild. 400+ is going to take a little more work, and if you are going to put the effort into the 4V heads, I would recommend something in the 500 HP range just to make it worthwhile! The 4V heads are a serious piece of performance hardware, don't waste them on a build that isn't pretty serious.
Old 10-15-2014, 03:51 AM
Quote:
Originally Posted by SDDL-UP View Post
Bud Mud,
ok,that is what i was looking for. I thought i read something about having to use spacers some where when using them on the 400,i'll pass then and rework the 400 heads. THANKS
__________________
Bud
lower mich
Old 10-15-2014, 07:51 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud ofGary Lewis has much to be proud of
I agree with what's been said. But there may be another option - Aussie heads. Talk to Tim. At one time he knew a guy with a set of them he was willing to sell.
__________________
Rusty: '81 F150 Ranger XLT 4x4 w/a 351M, RV cam, Performer carb & intake, C6, & 3.50's
Dad's: '81 F150 Ranger XLT 4x4: Down for restomod: Full-roller "stroked 351M" w/Trick Flow heads, Weiand intake, Street Demon 750/ZF5/3.50 gears w/Kevlar clutches
1969 Super Bee awaiting restoration
1950 Chevy 3100 in queue
Worst fear: I die and my wife sells my rides for what I've told her I have in them.
Old 10-15-2014, 06:48 PM
1960fordf350 1960fordf350 is offline
1960fordf350 is starting off with a positive reputation.
I have an edelbrock streetmaster 400 single plain manifold. That wouldn't work instead of using spacers? I didn't use it on my build, but used a dual plane performer 400 instead. Motor will be in truck soon I hope.
Old 10-15-2014, 09:03 PM
72fordgts 72fordgts is offline
72fordgts is starting off with a positive reputation.
If someone did build a 400 with 4V heads, could you not just use Sanderson shorty headers? They are made to fit 4V exhaust ports (you need to buy the adaptor plate for the 2V heads).
Sanderson Headers for Ford 351C Cleveland and 351/400M Big Block V8 engine applications.
Also, using pre 1975 400 heads or 351C-2V heads is an easy way to improve exhaust flow since they have a less restrictive exhaust port. These heads are usually pretty cheap too compared to 4V's or Aussies.
Old 10-16-2014, 05:08 AM
derbydad276 derbydad276 is offline
derbydad276 is starting off with a positive reputation.
bud here is a better buy for the same money
Aus Ford Parts - Aussie 351 Cleveland Specialists
Old 10-16-2014, 03:59 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Quote:
Some of the 400 intake manifolds do have enough "meat" around the ports to seal a 351C 4bbl port. Only one way to find out and that's to try it. As for the loss of velocity in them vs the 2 bbl ports, a lot of that is hype. I for one have driven a stock 351C 4 bbl car (71 Torino) and it was no slouch on the street at the bottomend, even with an auto trans and 3.00 rear. So I don't believe they'll inhibit a 400 at all.
__________________
89 Ranger supercab-- 302-4bbl-- 4 speed 68 Mercury Monterey 390 4 bbl C-6 77 F100 400M C-6 67 Mustang fastback 427 2-4
Old 10-16-2014, 09:13 PM
I pulled out my streetmaster. I laid the stock 400 turkey pan over it and the port runners are actually a 32nd smaller all the way around on the intake. What size are the intake ports on the 4V ?
Old 10-16-2014, 10:21 PM
There is quite a difference between 2V and 4V ports. The Wikipedia page gives the rough dimensions of the port size. I also included a link to a photo.
https://en.wikipedia.org/wiki/Ford_3...Cylinder_heads
http://www.panteraplace.com/Tech%20I...%20tongues.jpg
Old 10-16-2014, 10:36 PM
if you run aussie heads you can use standard 400 intake
and standard headers and from what I have read up so far these heads quench for reduced spark knock
Old 10-16-2014, 11:05 PM
According to what I have read from old Ford literature and the excellent write up from the Cleveland site, the closed chamber heads are not any better at resisting detonation. It seems the big issue with the 400's and detonation is the excessive deck clearance with stock pistons and stock replacement pistons. TMI pistons resolved this problem.
"The combustion chambers are either the "open" style or the "quench" style. The quench style chamber encloses the valves more tightly in order to reduce the volume of the combustion chamber. There is no power advantage in using the quench combustion chambers over the open combustion chambers, both combustion chambers have the same thermal efficiency, and both combustion chambers are equally resistant to detonation as well. The two practical advantages of a quench combustion chamber are (1) low rpm turbulence improves low rpm torque, giving a street motor a small degree better response to the throttle and (2) less machine shop work is required to achieve compression ratios in the range of 9.5:1 to 11.0:1 with flat top pistons. "
source:
Ford 351C STOCKERS ROCK!!: The 351 Cleveland Cylinder Head
Old 10-20-2014, 08:20 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
I have a 408" 400 4v head open chamber. Air gap edelbrock intake with spacer plates! Runs great in my 4wd crew. Used 351 Cleveland piston and bushed the con rods to fit piston pin. This is not a engine you slap together!!! I believe the standard head will work fine and throttle response will be better in low rpms, 1500 and down. But once past that the big heads take over!!! My engine is around 400 to 420 hrspwr. I live at 4000' elev. and hurts my hrspwr. I did port fillers to help keep port velocity up! Intake needle lots of work to make right! Camshaft about .520 minimum!
Similar Threads
test nickmobile67 Testing..... 0 08-08-2013 03:34 PM
Like Guns? Budman88 General NON-Automotive Conversation 14 02-26-2004 11:44 AM
magic... hyepwrd General NON-Automotive Conversation 25 12-08-2003 09:48 AM
Not more tests! 1997RangerXLT General NON-Automotive Conversation 31 07-08-2003 06:01 PM
Pictures Finally!!! ipkyss Super Duty & Heavy Duty 21 03-06-2003 11:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
